PIONEER XV-DV424 SM
VIDEO-DVD - SERVICE MANUAL
228.1 KB
PIONEER XV-DV424 SM service manual (1st page)
Preview of PIONEER XV-DV424 SM [1st page]
PIONEER XV-DV424 SM service manual (2nd page)
Preview of PIONEER XV-DV424 SM [2nd page]
    PIONEER XVDV-424 XVDV424 XVDV 424 XV DV424 XV-DV424
Hitachi VT-S390E Tápegység hiba! Megoldva!
Sziasztok! Saját videóm megadta magát, most került sorra. Rajzot nem találtam hozzá, ezért kérnék segítséget, hogy milyen tápfeszek mennek a tápról? Eddig amit cseréltem Q3 ( A1318 helyett 2SC3331 ) a IC1 ( L5431 helyett TL431 ) és van még egy Q5 ( 4048 ) ehelyett mit tegyek be? Valaki tudna segíteni?
Sony Sl-S770 vcr interrupted playback and AV display issues
I'm encountering an issue with my Super Betamax player. During playback, some cassettes abruptly stop playing at seemingly random points, accompanied by a sound similar to the one made when a tape reaches its end. This interruption also renders the rewind and forward buttons unresponsive. However, it does not impede the manual forwarding or rewinding of the cassette. The only solution seems to be ejecting the cassette and reinserting it. Occasionally, even this workaround fails, allowing only two seconds of playback before the problem recurs.
I sought guidance from the Mister Betamax troubleshooting page, which indicated that the tape safety device might be the root cause. I received additional advice suggesting that the issue could stem from one of the sensors within the VCR, possibly due to oxidized contacts causing intermittent operation. It was recommended to resolve this by carefully cleaning the contacts on the sensor switch responsible for detecting loaded tapes or the sensor that detects if the tape is "record-protected." Another suggestion was to monitor the output of these switches using an oscilloscope or voltmeter to determine if they are indeed the source of the problem.
I'm eager to hear if anyone has additional advice or personal experiences to share regarding this issue.
Additionally, I'm facing an AV cable problem where the yellow AV cable fails to display any video. While it used to work correctly, the AV audio cable still functions properly. As a temporary workaround, I've been using a coaxial cable and routing it through another VCR to utilize its AV output. However, I'm interested in exploring potential solutions to fix the issue with the yellow AV cable, if possible. Any insights or suggestions would be greatly appreciated.
Funai 25D 850 nem lehet TV adásra kapcsolni
Sziasztok! A fenti Funai videónak az a hibája, hogy a menübe belépve szépen be lehet programozni az adókat, de kilépve a menüből már nem lehet a programokat előhívni. Bekapcsolni lehet, de a progr. számok már nem jönnek be, ennél fogva az adók sem. A menübe visszalépve ott vannak, rögzítette. Az órát nem felejti el, reseteltem is, de nem boldogulok vele Tudtok valami okosat? Üdv Attila
Panasonic NV-HD670 betöltő mechanika törés
Üdv. Mindenkinek, A fenti készülékben eltörött egy rugóval feszített kar. Sajnos a SM-ban csak a shassi-ról van robbantott rajz, így megnevezni nem tudom a kérdéses alkatrészt de fényképet teszek fel hátha valakinek van bontott készülékből. Minden segítséget előre is köszönök. Üdv. Tibor
