Sziasztok! Boldog Új évet Mindenkinek!
Kérdésem az lenne a fenti hibára a megfelelő nk.bin telepítése megoldaná e a problémát? Illetve meglenne ez a fájl valakinek,vagy honnan tölthető le? A készülék NAVIGO A-N438 és egy bekapcsoló nyomógomb és egy reset gomb található rajta.
CorMyuS
There is no service manual of the Yamaha KX-250, anyone? I have fixed the mechanism of this unit, replaced the capstan motor (bad quality shreeking one with a better one), replaced the belts and works perfectly fine. Perfect audio, everything works great. However after testing it many times I reassembled the unit and did another test. Some tick noise is present in the audio.
The tick noise is present when executing a function, for example REW (most worse of all), FF or PLAY (only a few spikes randomly), also when using the remote. It is not a problem of the mechanism (motor) or a ground issue or something like that, disconnected it and problem still exists. Maybe it has something to do with static electricity because I have used the unit without HEAD cables attached to the mainboard (head input pins floating) however the pre-amplification circuit is working fine except of the noise. There are two IC's in this circuit, UPC1330HA head selector and a LA3161 pre-amplifier.
The LA3161 is a 2-channel preamplifier that has a circuit to reject ripple. Is it possible this IC is damaged (because of a (static) spike) and because of that the ripple rejection is no longer working? When I replace this IC the problem is solved?
Any ideas or do have some people any experience with this or recognize the sound behaviour discription? Anyone who can point me into the right direction?
Many thanks for any reply.
Szeretnék segítséget kérni a fenti kazánnal kapcsolatban.
A hibajelenség : rendszertelenül megáll , ilyenkor 3 rövidet egy hosszabbat villog a LED.
A füstgázérzékelő NTC cserélve lett. A kémény ellenőrizve, tisztítva. A panel A-Z-ig átforrasztva.
Esetleg valaki találkozott ilyen hibával és segítene ?
Köszi
Szabi
Az lenne a kérdésem, hogy van e valakinek LR 21-tipusú Weller pákaja?A kérdésem igazán a hozzátartozó heggyel lenne kapcsolatos az érdekelne, hogy milyen mechanikai méretei vannak tehát(átmérő,hosszúság,ha van benne furat akkor annak az átmérője és mélysége).Előre is köszönöm a segítséget mindenkinek! :taps2: :help:
Azért érdekelne a mérete mert szeretném átalakitani Hakko hoz mert annak is van furat a belsejében, illetve nem tudok szerezni hegyet hozzá méregdrága és olcsobb lenne ez a megoldás!A hakko páka:Hakko907.
