Hi, my SAMSUNG UE40D5000 tv doesn' t work anymore. The red led light indicating that the tv is plugged is not powered when I plug in the tv. The original power board modem is BN44-00473B. I have checked the voltage on the connector to the mother board of the tv, and it was 0 instead of 5.3V or 13V on the different pins, with the fuse still working and no obvious overheated part on the power board and no bulging capacitor seen neither.
I have then changed the power board with a used one bought on ebay, which model BN44-00473A is said to be compatible. It has then worked perfectly 2 days until yesterday. This morning I had to move a little bit the tv, what I did very gently, and got really disappointed as I plugged it and didn't see the red led light on anymore.
Since this morning, the power board seems to be broken once more ( I have moved from my original flat 1 week ago and don't have a multimeter to check once more that the fuse is ok and what are the voltage on the connector to the mother board )
I am wondering if this new power board failure is just bad luck, 2 days after receiving this other power board circuit ( that is a used unit, not brand new) or if the mother board could have damaged it. In the first case I would send the power board back to the seller, otherwise I will probably give up as I don't have time and skills to repair the tv.
My question is : do you think the mother board or another unit connected to it, can damage the power board ?
Thanks for your help and answers !
Üdv a Szakiknak!
Adott a fenti címben szereplő Tv. Bekapcsoláskor 5-öt villan lassú ütemben a készenléti Led. Tudja valaki, hogy ez mit jelent? A készülék amúgy működik, de régebben nem csinálta, -olyankor bekapcsoláskor csak 1-et villant.
(Csináltam róla videót is, de nem tudom hogyan tudnám ide betenni, mert egy google drive linket sem enged betenni.)
Köszönettel, Gyula
| Szevasztok!
A fenti csavarok nélküli fos nem kapcsol be készenlétről, csak villog. A Mainon az IC1302 pozíció számú IC-t melegítve bekapcsolható, ezt lehűtve ismét nem indul.
Main: BN94-11899D A013
Kijelző:CY-JM049BGHV1H
Minden segítséget előre is köszönök!
Egyúttal maint is keresek hozzá.
norty
Most került hozzám ez a tv azzal a hibával, hogy az emberek arcán zöldes foltok jelennek meg. A kiemeltnél nagyon a filmes beállításnál nem látszódik annyira. Teszek fel képet is róla.Még teszek fel a kijelzőről is képet, és rendeltem AS19-et.
