SANSUI TDA128PIN B2B29 A-25
TV - EPROM
Type: (E2P)
4.1 KB
EPROM
Looking for similar sansui manual?
    SANSUI TDA-128PIN B-2B-29 TDA128PIN B2B29 A25 TDA 128 PIN 29 25 A-25
Sansui lcd chassis B.FL.MG04-5431 model sv-3050lcd take long to start and shuts down after 20 sec.
Hi,i have this sansui lcd sv-3050 that i am fixing if i power it on it takes some time to light up and if it manages will shut down in 30 secs.i have changed some caps(power supply)which were bulged.i am suspecting the inverter board (dafron v144-48v1448.001/f)is there a way to bypass or remove the protection on the inverter board and ic it advisable?
