SANYO FX-01
CAR-AUDIO - SERVICE MANUAL
2.7 MB
CAR-AUDIO
SANYO FX-01 service manual (1st page)
Preview of SANYO FX-01 [1st page]
SANYO FX-01 service manual (2nd page)
Preview of SANYO FX-01 [2nd page]
    SANYO FX-01 FX01 FX 01
Becker Cascade BE7944 need help!
Hello to everyone!
Thanks in advance if someone can help)
I have a problem with replacement of malfunctioned final amplifier at Cascade BE7944.
It is play sounds through front loudspeakers with distortion.
It is not a problem with wires (I have tested it them with ohmmeter) and loudspeakers (brand new).
I have replaced with Traffic pro and it worked fine.
Radioengineer has announced the verdict - problem with final amplifier and it is must be replaced, and preferably with service manual or schematic, which I do not have. And I did not allow him to unassemble my Becker just "for to watch how it is looks from inside")
The problem is following:
1. Do someone have and can share with me with service manual or schematic of Becker Cascade BE7944.
2. As far as I understand BE7944 is further development of schematic Audio 10 ECE Typ 6011 (or 4011), which service manual is available at Internet - can I use it as general background for BE7944?
3. At present time unfortunately there is no possibility to find original MLT TDA 7454, only CHN or unnamed versions. I do not want to install that, but according to datasheet for TDA 7454 it can be replaced with TDA 738 *. And TDA738 * can be raplaced with TDA 7560 or TDA 7850 (in my case TDA 7851 L). If it is possible to replace TDA 7454 with TDA 7851 L and with which modifications? And will I not lose the “Backer surround” function?
4. Any other suggestions? Please withought "sell this dinosaur"
 I have written to Harman / Becker with this problem but still no answer ...
Thanks to all!
Pioneer autórádióba PAL012A IC-t keresek
Egy Pioneer DEH-1600UB autórádióba keresek PAL012A végfok IC-t. A régi csont zárlatos. A SINI-nél van, horror áron, az egész készülék nem ér annyit. Ha valakinek volna bontásból, vagy helyettesítőt tudna sokkal olcsóbban, megköszönném.
Üdvözlettel:
Sherwood XA-1100 autó végfok halkan szól!
Ma szedtem szét és a végfok tranzisztorait átmértem, de mind jó. De tápra kötve halkan szól, hangerőt lejjebb  lelehet venni, de nagy hangerőt nem ad ki. Rajzot nem találtam hozzá? Lehet hogy a bemenetnél van gond?
Sony XR-CA600X autórádió bekapcsolás után néhány percen belül megnémul, csak több órás áramtalanítás után működik ismét...
Kedves Hozzáértők!
Küzdök a címbéli kézi készülékkel.
Előjáték: A tulaj szerint bekapcsolás után egy idő múlva szabályozhatatlan a hangerő (nem változik a kezelőszervek állítása ellenére), majd megnémult, és azóta sem adott hangot.
Javítás 1: A végfok IC lábainak forrasztásai felrepedeztek. Az összes érintett lábat és a csatlakozókat is átforrasztottam, az egész panelt nagyítóval átnéztem. Visszaadás után a működés próba sikeres volt, 1,5 órás járatás után is működött.
Jelenleg: Másnap bekapcsolás után pár perc múlva megnémult, és azóta sem ad hangot. Látszólag minden kezelőszervre reagál, csak a hang hiányzik (lényegében az eredeti hibajelenség visszatért).
Javítás 2: Kipróbáláskor pár perc után egy-egy pillanatra elnémult, majd teljesen elhallgatott. Sem magnóról, sem rádióról nem szólaltatható meg. A hangerő állításra a kijelző reagál, de hang nincs. Ha kikapcsolom, de áram alatt marad, akkor továbbra sem ad hangot bekapcsolás után sem.
DE, ha órákig áramtalanítva van, akkor megint pár percre képes rendesen szólni.
Amit mértem: Első gyanú, a némítás funkciók ellenőrzése. De nem. A feszültségek a processzor és a némító tranzisztorokon is normálisak. A végfok IC  sem kap némítást kiváltó jelet (stby, mute).
Mértem a hangfrekvenciás jelet. Az IC331 egy TDA7406T igencsak multi ic. Bemenetválasztás, hangerő szabályzás, EQ, spektrum analizálás, FM stereo decoder, stb.
Az MPX jel megérkezik a bemenetére, de amikor némulás van, akkor a kimenetein semmi nincs. Szerintem rendellenesen melegszik is. Nem tűzforró, de a feszültség szabályzó IC-n kívül ez a legmelegebb.
Van mégegy hibajelenség, ami zavar: Amikor elnémul, egy pár percig kijelző szinten is rendben működik, meg az MPX jel változásából is látom, hogy ok lenne, csak a TDA IC-ből nem jön jel.
DE egy idő múlva mér ez sem igaz. Ha hangolni próbálom (seek +/-) ,akkor nem talál adót. Nem áll meg a keresés. Pedig a tuner signal kimenetén látom, hogy elhalad a hangolás adók "felett", és az MPX jel is kitisztul 1-1 pillanatra, de nem áll meg a hangolás.
Ez a multi TDA IC szerintem belepofázik a hangolásba is, mert a tuner egy vegyes digitál (i2C)/analóg egység, és én már nem látom át a működését.
És a kérdés: Okozhat a TDA7406T önmagában ilyen hibajelenségeket? Mondjuk kicserélni nem tudnám, mert nem lehet kapni (HQ, Farnell, TME, ASWO, EBAY).
Előre is köszönöm!
Gábor
