SANYO VPC-WH1W WH1EX WH1GX WH1BL WH1EXBL WH1GXBL WH1YL WH1EXYL WH1GXYL
STILL CAMERA - SERVICE MANUAL
5.3 MB
STILL CAMERA
SANYO VPC-WH1W WH1EX WH1GX WH1BL WH1EXBL WH1GXBL WH1YL WH1EXYL WH1GXYL service manual (1st page)
Preview of SANYO VPC-WH1W WH1EX WH1GX WH1BL WH1EXBL WH1GXBL WH1YL WH1EXYL WH1GXYL [1st page]
SANYO VPC-WH1W WH1EX WH1GX WH1BL WH1EXBL WH1GXBL WH1YL WH1EXYL WH1GXYL service manual (2nd page)
Preview of SANYO VPC-WH1W WH1EX WH1GX WH1BL WH1EXBL WH1GXBL WH1YL WH1EXYL WH1GXYL [2nd page]
    SANYO VPCWH-1W WH-1EX WH-1GX WH-1BL WH-1EXBL WH-1GXBL WH-1YL WH-1EXYL WH-1GXYL VPCWH1W WH1EX WH1GX WH1BL WH1EXBL WH1GXBL WH1YL WH1EXYL WH1GXYL VPCWH WH EX GX BL EXBL GXBL YL EXYL GXYL VPC WH1W VPC-WH1W
Samsung VP-D20 videokamera nem fókuszál(részemről megoldva)
üdv: címbeli kamerán nem működik a fókusz(zoom jó) Jó lenne valami információ, hogyan működik ezen a fókusz. A tanyán csak kapcs.rajzot találtam, jó lenne a mechanikáról is egy rajz, mielőtt szétkapnám.Neten eddig csak fizetőst találtam. Bálint
DCR-HC39E Flange Back Adjustment.
Adjusting method:
Order Page Address Data Procedure
1 0 01 01
2 E FD
Set the bit value of bit4 is
“1”, and press PAUSE
button. (Note 6)
3 6 01 13 Press PAUSE button.
4 Wait for 2 seconds.
5 6 01 15 Press PAUSE button. (Note 7)
6 6 02 Check the data changes to
“01”.
7 6 0C Check the data is “00”.
8 F 57 Check the data is “00” to
“0B”.
Note 6: For the bit values, refer to “6-4. SERVICE MODE”, “4-
3. 3. Bit value discrimination”.
Note 7: The adjustment data will be automatically input to page:
F, address: 11, 48 to 58.
I've done lots of flange back adjustments on other Sony camcorder models but, on this one, when I went to instruction 2, page E, address FD, the data was 40, so I change that to 39 (giving a bit4 value of '1' ) and pressed the PAUSE button (to write to the registry), and carried on with the other instructions. As soon as I changed page E, address FD,  data to 39 the screen of the camcorder went black and stayed like that throughout the other instructions. As nothing seemed to happen, I went back to page E, address FD, and changed the data back to 40 and pressed the PAUSE button, to write to the registry. The camcorder seemed to start running through its automatic flange back adjustment, but then seemed to be bricked, with error E:60:00 displayed and the focus lens vibrating rapidly back and forth at a high frequency, giving a very blurred image. On disconnecting the adjustment commander, the camera would display no image, when turned on, just a blue screen. After 90 minutes of writing correct values to the registry, the camera went through its correct automatic flange back adjustment, and all was well.
I then tried to do the flange back adjustment on another DCR-HC39E, and just missed out instruction 2 and that worked fine and made correct adjustments. Is the service manual incorrect, or am I missing something?
Diaképek mentése CD-re -megoldható egyszerűen?
Köszöntök Mindenkit! Ismerősöm, aki hegyvidéki turisztikai vezető, azon kéréssel fordult hozzám, hogy a régi - ma már szinhibás- diaképeket lehet-e menteni CD-re. Akinek van tapasztalata e téren, megkérem vázolja a teendőket. Ismerősöm nevében is köszönet érte. Üdvözlettel. welding alt
Panasonic NV-GS17 kamera LCD-je nem működik
Sziasztok. A címbeli miniDV kamera került hozzám aminek az a baja, hogy az LCD panelon semmi kép nincs. A nézőkében látható a kamera képe és a lejátszott video is. Valószínűsítem, hogy az átvezető fólia a rossz. Kérdésem, hogy milyen tipusú kell bele és hol lehetne beszerezni?(még nem szedtem szét.)
