SCHAUB-LORENZ TOURING T 30 SM
4.4 MB
Looking for similar schaub manual?
SCHAUB-LORENZ TOURING T 30 SM service manual (1st page)
Preview of SCHAUB-LORENZ TOURING T 30 SM [1st page]
SCHAUB-LORENZ TOURING T 30 SM service manual (2nd page)
Preview of SCHAUB-LORENZ TOURING T 30 SM [2nd page]
    TOURING 30 SCHAUB LORENZ
ONKYO TX-DS494 low volume problem solving experience
Hello. here is a message to share my experience in solving a problem that appeared on the home-cinema amplifier ONKYO tx-DS494. In order to sell this amplifier I had to check if all the outputs and all the functions works properly. On the back of this amplifier you have to frontal output : A and B. I connect a pair of speaker on A output : no problem. I can adjust volume. when i connect the pair to the b output and turn the volume knob no sound came out of the speakers until I reach a level defined by I don't know what. :hmmm: My volume level goes from 0 to 80db ( if I remember well ). from 0 to 23 db no sound and when I reach 24 dn sound increase and stabilize. With hearphone connected, i don' have this problem so I conculde that amplifing transistor could not be incriminated. I checked on the service manual and saw that there are two or three component that could be the source of the problem : the main processor, some capacitors on the output PCB and relays. I began testing capacitors: no pb. then I thought that if cannot be the main proc because it ( I think ) works in a binary mode: it works or it doesn't. so I decided to switch between themselves the two relay and :super: : it works. The relays was in fault and did not switches properly. here is my experience in repairing an amplifier
Fisher CA9335 (Standby Táp kevés 9V nem indul!)
Sziasztok! A fent említett förmedvény került hozzám. Standby-ból látszólag indul, kijelzők élednek, de gombnyomásra bizonytalanul jeleznek és a ledek elég halványak. A 12,7V helyett 8,9V van 7805 3-as lábán. Hálózati indító relé nem húz meg! Standby tápot átnéztem, hibát nem találtam. Leválasztottam a készülékről D4915 és 4916 felemelésével, külső pufferkondival 17V-ot ad üresbe tehát valami meghúzza, de nem jövök rá hogy mi a franc.... Van valakinek ötlete?
Philips 15 GF 832-06-S lemezjátszó erősítő hibás, hiányos.
Üdvözlet Mindenkinek!
A fent jelzett, ajándékba kapott kis lemezjátszót szeretném feléleszteni. Valaki korábban már megpróbálta, mindkét csatornából hiányoznak alkatrészek... Nagyon kellene egy kapcsolási rajz az erősítőről, ehhez kérem a segítségeteket.
Marantz SR 930 receiver alkatrész azonosítás
Sziasztok! Egy Marantz SR930 van nálam javításon, a hűtőborda a végtranzisztorokkal együtt ismeretlen helyen tartózkodik, azokat kell pótolnom. Sajnos rajzot nem találtam, de fotók alapján a tranyókat sikerült azonosítani és beszerezni, viszont a lefotózott alkatrészről nem találtam semmit. Gondolom termisztor vagy dióda lehet, mert a bordára volt csavarozva, de az egyiket amputálta az előző tulaj, a másik pedig nincs is meg. Valaki tudja esetleg, mi lehet ennek az alkatrésznek a típusa, vagy mivel helyettesíthetném? Esetleg kapcsolási rajza nincs hozzá valakinek? Előre is köszi a segítséget! Kiegészítés: itt találtam róla belső fotókat. Más erősítőkben is találkoztam ilyen alkatrésszel, a rajzon (több, sorba kötött) diódaként szerepel a meghajtó tranyók hőkompenzálására. STV-3H, STV-4H, ST-3A és hasonló diódákat találtam nagyon hasonló tokozásban, de elég eltérő paraméterekkel.
