SONY DVP-NS500V,NS700V SM
VIDEO-DVD - SERVICE MANUAL
25.4 MB
SONY DVP-NS500V,NS700V SM service manual (1st page)
Preview of SONY DVP-NS500V,NS700V SM [1st page]
SONY DVP-NS500V,NS700V SM service manual (2nd page)
Preview of SONY DVP-NS500V,NS700V SM [2nd page]
    SONY DVPNS-500V NS-700V DVPNS500V NS700V DVPNS 500 NS 700 DVP NS500V DVP-NS500V
Sony slv-x57
Sziasztok, tudnátok-e egy robbantott rajzot küldeni, szétszedtem a mechanikát az üzemmodkapcsoló kitisztitása miatt egy hete, most meg nem tudom összerakni. Konkrétan a lendkerék féktuskoja akasztott meg, amit utólag nézve nem is kellett volna kivenni,négy müanyagalkatrész és egy rugó nem talál a helyére, köszi.
Sony Sl-S770 vcr interrupted playback and AV display issues
I'm encountering an issue with my Super Betamax player. During playback, some cassettes abruptly stop playing at seemingly random points, accompanied by a sound similar to the one made when a tape reaches its end. This interruption also renders the rewind and forward buttons unresponsive. However, it does not impede the manual forwarding or rewinding of the cassette. The only solution seems to be ejecting the cassette and reinserting it. Occasionally, even this workaround fails, allowing only two seconds of playback before the problem recurs.
I sought guidance from the Mister Betamax troubleshooting page, which indicated that the tape safety device might be the root cause. I received additional advice suggesting that the issue could stem from one of the sensors within the VCR, possibly due to oxidized contacts causing intermittent operation. It was recommended to resolve this by carefully cleaning the contacts on the sensor switch responsible for detecting loaded tapes or the sensor that detects if the tape is "record-protected." Another suggestion was to monitor the output of these switches using an oscilloscope or voltmeter to determine if they are indeed the source of the problem.
I'm eager to hear if anyone has additional advice or personal experiences to share regarding this issue.
Additionally, I'm facing an AV cable problem where the yellow AV cable fails to display any video. While it used to work correctly, the AV audio cable still functions properly. As a temporary workaround, I've been using a coaxial cable and routing it through another VCR to utilize its AV output. However, I'm interested in exploring potential solutions to fix the issue with the yellow AV cable, if possible. Any insights or suggestions would be greatly appreciated.
SONY EV-S550E Video 8 nem játsza le a kazettát ,illetve zajos a kép...
Sziasztok A címben szereplő video8 hoz keresnék rajzot de sajna itt a tanyán nincsen hozzá próbáltam keresni hozzá rajzot de nem találtam . Hibe jelenség csikozva játszik le és így is vesz fel valoszinü fejhibás de kéne hozzá egy pontos tipus hogy milyen fej való bele ezért keresek hozzá gyári rajzot hogy megtudjam nézni a fej tipusát . Ha valaki tud segitsen . Már régóta megy a topik, és nem a rajz a lényeg benne. Légy szíves igazítsd ki a címet!
SONY SLV-SE710N
Sziasztok! Segítségeteket szeretném kérni! Behoztak hozzám egy ilyen típusú videót,az a gondom vele,hogy a lejátszás fekete-fehér,és felvétel is,akár RF-ről-akár av-ról..a normákat már váltogattam,nem reagál,csak egy dolog,ami érdekes,hogy ha a menüben átállítom a normát mesecamra,akkor a régi felvételeket színesen játsza le,de felvenni így is csak fekete-fehérben vesz fel.... van valakinek valami ötlete,hogy mi lehet ez a hiba? Köszönöm a segítséget! Köszönettel:Péter
