SONY DVPC 660 670D
VIDEO-DVD - SERVICE MANUAL
25.2 MB
SONY DVPC 660 670D service manual (1st page)
Preview of SONY DVPC 660 670D [1st page]
SONY DVPC 660 670D service manual (2nd page)
Preview of SONY DVPC 660 670D [2nd page]
    SONY DVPC 660 670D 670
Sony Sl-S770 vcr interrupted playback and AV display issues
I'm encountering an issue with my Super Betamax player. During playback, some cassettes abruptly stop playing at seemingly random points, accompanied by a sound similar to the one made when a tape reaches its end. This interruption also renders the rewind and forward buttons unresponsive. However, it does not impede the manual forwarding or rewinding of the cassette. The only solution seems to be ejecting the cassette and reinserting it. Occasionally, even this workaround fails, allowing only two seconds of playback before the problem recurs.
I sought guidance from the Mister Betamax troubleshooting page, which indicated that the tape safety device might be the root cause. I received additional advice suggesting that the issue could stem from one of the sensors within the VCR, possibly due to oxidized contacts causing intermittent operation. It was recommended to resolve this by carefully cleaning the contacts on the sensor switch responsible for detecting loaded tapes or the sensor that detects if the tape is "record-protected." Another suggestion was to monitor the output of these switches using an oscilloscope or voltmeter to determine if they are indeed the source of the problem.
I'm eager to hear if anyone has additional advice or personal experiences to share regarding this issue.
Additionally, I'm facing an AV cable problem where the yellow AV cable fails to display any video. While it used to work correctly, the AV audio cable still functions properly. As a temporary workaround, I've been using a coaxial cable and routing it through another VCR to utilize its AV output. However, I'm interested in exploring potential solutions to fix the issue with the yellow AV cable, if possible. Any insights or suggestions would be greatly appreciated.
SONY SLV-SE727E - tracking hiba?
Sziasztok! A fenti videó az LP-t szépen felveszi, le is adja, de SP-ben tracking jellegű hibát produkál. Saját és más felvétellel is. Samuknál szokott ilyen lenni, amikor elmegy az opciója. Ami zavar, hogy SP-ben rossz, LP-ben nem. Használta az ügyfél rendesen. Kopott, vagy opcióhibás ez is? Ha valakinek van ötlete, kérem, ossza meg velem! Szép napot! Laci
Sony SLV-E780 táp
Üdv! Van nálam egy Sony videó. Nem indul a tápja, a szokásos katt-katt-katt másodpercenként. Kicseréltem benne az összes elkót, az optót, a feszültség referenciát, kínomban már a tápIC-t is, mindhiába. A rajz: http://kepfeltoltes.hu/view/091112/sony_www.kepfeltoltes.hu_.gif A pirossal jelölt helyeken leválasztottam az áramkört, hogy ne zavarjon be, a zöld alkatrészek cserélve. Műterhelés van a kimeneten. A bemeneten megvan az egyenirányított hálózati feszültség, a tápIC megkapja a névleges tápot (13V), a szekunder oldalon a kattogással szinkronban megjelenik a feszültség is arra a rövid időre, amíg egy impulzus lefut. Ellenállásokat végigmértem, mindegyik névleges. A bemeneti áramkorlátozó értéke 0.33 ohm, ezt nem tudom ellenőrizni, a műszerem nem ennyire pontosm, de az értéke kisebb mint 1 ohm, úgyhogy jónak feltételezem. Tudtok segíteni? Mit nézzek még ezen a szutykon? DM
Sony EV-S1000E: service manual is missing the Power Supply schema
Hello everybody,
I'm trying to fix an old Sony vcr with some PS issues and unfortunately from the service manual (the one with electric schema) I've downloaded from this very good service the PS circuit is missing.
Anyone with the original manual may help me?
Thank you!
Franco
