SONY GV-D1000,D1000E LEVEL-3 VER-1.1
VIDEO-DVD - SERVICE MANUAL
24.5 MB
SONY GV-D1000,D1000E LEVEL-3 VER-1.1 service manual (1st page)
Preview of SONY GV-D1000,D1000E LEVEL-3 VER-1.1 [1st page]
SONY GV-D1000,D1000E LEVEL-3 VER-1.1 service manual (2nd page)
Preview of SONY GV-D1000,D1000E LEVEL-3 VER-1.1 [2nd page]
    SONY GVD-1000 GVD1000 D1000E GVD 1000 GV D1000 1.1 GV-D1000
Sony slv-x57 javíthatatlan?
Sziasztok! Apum kitett magáért. Van egy címben szereplő video, azt mondták neki nem érdemes megjavítani, erre miszlikbe szedte :( Miért nem hallgat soha rám... Ki ismeri ezt a gépet? Netán tényleg egy gagyi gép és nem volt kár érte? Üdv: Pityesz
Sony Sl-S770 vcr interrupted playback and AV display issues
I'm encountering an issue with my Super Betamax player. During playback, some cassettes abruptly stop playing at seemingly random points, accompanied by a sound similar to the one made when a tape reaches its end. This interruption also renders the rewind and forward buttons unresponsive. However, it does not impede the manual forwarding or rewinding of the cassette. The only solution seems to be ejecting the cassette and reinserting it. Occasionally, even this workaround fails, allowing only two seconds of playback before the problem recurs.
I sought guidance from the Mister Betamax troubleshooting page, which indicated that the tape safety device might be the root cause. I received additional advice suggesting that the issue could stem from one of the sensors within the VCR, possibly due to oxidized contacts causing intermittent operation. It was recommended to resolve this by carefully cleaning the contacts on the sensor switch responsible for detecting loaded tapes or the sensor that detects if the tape is "record-protected." Another suggestion was to monitor the output of these switches using an oscilloscope or voltmeter to determine if they are indeed the source of the problem.
I'm eager to hear if anyone has additional advice or personal experiences to share regarding this issue.
Additionally, I'm facing an AV cable problem where the yellow AV cable fails to display any video. While it used to work correctly, the AV audio cable still functions properly. As a temporary workaround, I've been using a coaxial cable and routing it through another VCR to utilize its AV output. However, I'm interested in exploring potential solutions to fix the issue with the yellow AV cable, if possible. Any insights or suggestions would be greatly appreciated.
Sony EV-C400e mechanika javítás (fogaskerék beszerzése)
Sziasztok! A fenti Hi8-as video mechanikája pörgetésnél zörög és meg is áll. Kiderítettem, hogy a bal csévélő orsó fogaskerék része el van repedve ezért összeakad a hajtó fogaskerékkel. Kérdésem, hogy honnan lehetne ilyet beszerezni, vagy hogyan lehetne javítani? Az a baj, hogy a műanyag kiszáradt és összezsugorodott. A belső fém rész szétfeszítette. Összehúzni nem lehet a fogakat. Üdv.
Sony SLV-X9N videó eject utasításra kiadja a kazettát, de rögtön vissza is tölti.
Sony SLV-X9N videó eject utasításra kiadja a kazettát, de azonnal vissza is tölti. A mode-switch kitakarítva, a panelon lévő mikrokapcsoló megjavítva. A  sasszin lévő fogaslécen egy kis műanyag lapka le volt törve, azt visszaépítettem, remélem jól. Persze, ha elég gyors vagyok, ki tudom venni a kazettát, de akkor is visszaindul a kazetta fészek, de természetesen elakad a reteszelő lemez (remélem, ez a neve) miatt. Tudna valaki tanácsot adni, hogy hogyan tovább?
Köszönettel:
