SONY KDL-32S2400 40S2400 CHASSIS WAX2 REV.1 SM
14.9 MB
SONY KDL-32S2400 40S2400 CHASSIS WAX2 REV.1 SM service manual (1st page)
Preview of SONY KDL-32S2400 40S2400 CHASSIS WAX2 REV.1 SM [1st page]
SONY KDL-32S2400 40S2400 CHASSIS WAX2 REV.1 SM service manual (2nd page)
Preview of SONY KDL-32S2400 40S2400 CHASSIS WAX2 REV.1 SM [2nd page]
    SONY WAX-2 KDL32S2400 40S2400 CHASSIS WAX2 REV.1 KDL 32 2400 40 WAX REV. 32S2400
Sony KV-X2961D a menü H szinkron hiba ! Megoldva.
Üdv mindenkinek! A fenti készülék menüje H szinkron hibás.A kép rendbe van, menü csíkok jelenek meg....Javaslat mit nézek meg... Köszönöm Üdv Kocsis Gy
Sony KDL-37W5500 - Blinks 8 times (Audio Error)
Hello to everyone, i have a problem with this Sony LCD Sony KDL-37W5500 Chassis EX2L MAINBOARD: 1-878-942-22 PANEL: T370HW02 Audio Amp: TAS5602 Sound System: CXA3785R-T6 main CPU: EMMA3 (under heat sink should be MB91F313APMC-GE1) Power Supply: G4, 3H267W, PSC10270F When i try to turn it on it clicks relay, blinks 1x Green Led, then it shuts down and blinks 8x Red Led. Looking at service manual it should be an Audio Error. When i try to enter Self Diagnostic Menu it just wont light up the screen. I do the sequence "I+" "5" "V-" "Power" and it powers up regularly-fault 1xgreen 8x red, black screen. From power supply i get all the voltages, except that 15V is 17.4V constant, but at the moment of powering it overshoots at 24V briefly. Also i don't get D3.3V voltage. I have 12V on regulator BD9540EFV, but enable pins 3 and 12 are held too low on 1.6V, and it need at least 2.2V to enable output, so i dont have 3.3V, only 0,7V. DVDD 3.3v is logic supply, so i dont get how CPU gets logic levels from ICs for error when there is no Logic Supply... When i measure the power for audio amplifier TAS5602DCAR it should be 13V i suppose, but it gets 17.4V, from the CON1300 pins 4 and 5. It is ok for that IC, it works on voltages until 30V, but I worry if that does not affect some other processes. Fault signal from audio amp TAS5602DCAR is on PIN19 and it is 3.3V that is HIGH and it suggests Normal Operation. On sound system IC CXA3785R-T6 pin44 the VFAULT signal is LOW 0.7V, that is too normal operation. But on audio amp pin18 TAS5602DCAR RESET is held in LOW and it does not go to HIGH to get out of the reset mode. That pin is controlled by main CPU signal X_SP_Mute. On sound system IC CXA3785R-T6 pin43 X_Protect output is LOW 0.4V that means ERROR. In datasheet it says X_PROTECTOUT outputs “L” when input voltage (SPxP/N) become under 3.0V. That is on pins 61-62 and 63-64, and if I understand right it needs to have 3+ V DC to output High Normal signal? Isnt that a bit too high to have on speakers? I measure 0V DC there, and 25mV AC. Also i can not find anywhere schematics for PSU board PSC10270F(3H267W), i need it because i think that this 15V should be around 15V not 17,4V. I did find zener diode that i think acts as a stabilizator and it measures ok, but i would replace it if i knew the markings that can not be read. All google stuff is from my posts so google wont help :) What do you think can be the main problem and solution for this ? I exclude replacing whole board I have and Audio Amp IC coming soon to replace, but i think that wont help. p.s. If anyone wants i can upload all pdfs that i have, ex2l SM, datasheets for audio ICs, datasheet for 3,3V regulator ect...
Spanyol gyártású SONY TV
Kedves Fórumtársak! Teljesen új tag vagyok ezen a fórumon, de úgy általában sem írogatok csak azért hogy valakit a szövegemmel untassak. Engedjétek meg ezért hogy kínlódásom eredményét - hátha valakinek még hasznos lehet alapon - közzétegyem. A devecseri használtcikk-kereskedőktől vásároltam egy SONY-KV-29LS60E típusú készüléket - nem is olyan kevés pénzért... A TV-hez természetesen nem volt távvezérlő, de ez nem volt annyira újdonság számomra. Ebből kifolyólag csak az alapfunkciókat tudtam kipróbálni. Aztán rendeltem egy e típushoz való távirányítót. Ahogy azt rémálmaimban láttam a készülék semmilyen funkciója nem működött vele. A masina távvezérlő vevő-részét külön tápról teszteltem, úgy működött. A TV 5V-os tápja is sima volt. A vevő kimenetén azonban 2-3V-os 2,5uS-os 16-21kHz-ig változó frekvenciájú tüskék voltak láthatóak. A kapcsolási rajzon látható volt a processzor bemenete, ahol fogadta volna az IR jeleket. Ez a bemenet azonban kisimpedanciás kimenetként működött. Nézegettem egy darabig a kontroller bemeneti szűrőjét, nem tudtam miért furcsa, aztán rájöttem. Én még C-R szűrőt nem, csak R-C szűrőt láttam . Néztem a nyákon is a rajzon is a jelút szempontjából C-R szűrő van beépítve- miért? Ezzel még nem oldódott meg a probléma. A SINI-nél megkérdeztem: 18 eFt lenne csak a chip. Aztán lesz ami lesz alapon végigforrasztottam mind a 100 lábát. Megszűnni látszik a hiba, veszi a távkapcsoló jeleit. Tanulság: óvakodjatok a spanyol gyártású TV-ktől. Tele vannak forrasztási hibákkal. Én már a 3-dikkal kínlódtam meg. Kettő tuner-hibás volt a forrasztási hibák miatt, ez egyenlőre még csak távkapi-vevőhibás. Örülök, ha tudtam valakinek segíteni. Akit untattam, attól elnézést kérek. Nem vagyok TV-szerelő! Áldott húsvéti ünnepet kívánok mindenkinek!
sony bravia kdl-40p3020 bekapcsolás után kb 20-30 perc mulva serceg a hangszóró hangerőtől függetlenül
üdv, segitséget kérnék .kaptam egy sonybravia kdl-40 p3020 LCD TV bekapcsolás után néhány percel erős sercegés hallatszik a hangszóróból , ami egy idő után megszünik,majd ujra kezdi. nem azonos időben -ideig . Köszönöm a segitséget előre is
