Hello to everyone, i have a problem with this Sony LCD
Sony KDL-37W5500
Chassis EX2L
MAINBOARD: 1-878-942-22
PANEL: T370HW02
Audio Amp: TAS5602
Sound System: CXA3785R-T6
main CPU: EMMA3 (under heat sink should be MB91F313APMC-GE1)
Power Supply: G4, 3H267W, PSC10270F
When i try to turn it on it clicks relay, blinks 1x Green Led, then it shuts down and blinks 8x Red Led.
Looking at service manual it should be an Audio Error. When i try to enter Self Diagnostic Menu it just wont light up the screen. I do the sequence "I+" "5" "V-" "Power" and it powers up regularly-fault 1xgreen 8x red, black screen.
From power supply i get all the voltages, except that 15V is 17.4V constant, but at the moment of powering it overshoots at 24V briefly.
Also i don't get D3.3V voltage. I have 12V on regulator BD9540EFV, but enable pins 3 and 12 are held too low on 1.6V, and it need at least 2.2V to enable output, so i dont have 3.3V, only 0,7V.
DVDD 3.3v is logic supply, so i dont get how CPU gets logic levels from ICs for error when there is no Logic Supply...
When i measure the power for audio amplifier TAS5602DCAR it should be 13V i suppose, but it gets 17.4V, from the CON1300 pins 4 and 5. It is ok for that IC, it works on voltages until 30V, but I worry if that does not affect some other processes.
Fault signal from audio amp TAS5602DCAR is on PIN19 and it is 3.3V that is HIGH and it suggests Normal Operation.
On sound system IC CXA3785R-T6 pin44 the VFAULT signal is LOW 0.7V, that is too normal operation.
But on audio amp pin18 TAS5602DCAR RESET is held in LOW and it does not go to HIGH to get out of the reset mode. That pin is controlled by main CPU signal X_SP_Mute.
On sound system IC CXA3785R-T6 pin43 X_Protect output is LOW 0.4V that means ERROR.
In datasheet it says X_PROTECTOUT outputs “L” when input voltage (SPxP/N) become under 3.0V.
That is on pins 61-62 and 63-64, and if I understand right it needs to have 3+ V DC to output High Normal signal?
Isnt that a bit too high to have on speakers? I measure 0V DC there, and 25mV AC.
Also i can not find anywhere schematics for PSU board PSC10270F(3H267W), i need it because i think that this 15V should be around 15V not 17,4V. I did find zener diode that i think acts as a stabilizator and it measures ok, but i would replace it if i knew the markings that can not be read.
All google stuff is from my posts so google wont help :)
What do you think can be the main problem and solution for this ?
I exclude replacing whole board
I have and Audio Amp IC coming soon to replace, but i think that wont help.
p.s.
If anyone wants i can upload all pdfs that i have, ex2l SM, datasheets for audio ICs, datasheet for 3,3V regulator ect...
Szevasz (tok) mindenkinek.
Kedves kollégák. A segítségetekre volna szükségem.Ez most megfogott egy kicsit.
Beesett az ajtón egy piszok nagy lcd /46-os/ tv, cof és vibrálási hibával.
A cof, nem volt ellenfél, de a háttérvilágításom leállt. Sajnos a tápról, csak hozzávetőleges a rajz ami itt fellelhető, így a hibajelzés vonalat nem lehet lekövetni, és apró részletek melyek fontosak lennének a táp, illetve a fénycső áramkör ellenőrzésénél, az nincs rajta. Jelenleg úgy néz ki, hogy a táp az menne, /de a rajtalévő csatlakozókon keresztül van felfűzve a hibajelzés/. Az itt fellelhető hasonló rajz szerint az 5-ös hibakód =DCALERT3=. Az itteni rajz szerint ez egy feszültség osztó és egy zeener lenne, de sehol nem lehet fellelni.
Sajnos a tápon látszik, hogy nem teljesen egyforma a rajz szerintivel, ( az itteni rajz =sony kdp-46D2000- től 3500-ig).
Ha van valakinek ötlete, kérem segítsen, vagy ha valaki tud egy pontos rajzot (unimann..:) ) kérném ossza meg velem, mert így nem valószínű, hogy az "uj rendszer szerint (jelölés az alkatrészeken nuku)ezt egyhamar megtalálnám, és ha sikerül szórabírni akkor nem hiába mentettem meg a kijelzőt.
Köszönettel minden ötletért: kocici
Sony KV29CL11K típusú tv-be kiment a sorvégfok(BU2015DX)gyárilag ez volt benne,kicseréltem de azonnal elszállt,ezután kivettem és elkezdtem méregetni a tápok mindenhol megvannak,minden kondit kimértem-ezek is jók,panelhiba nincs,a végfok meghajtórészében is rendben van minden,a függőleges sor ic lehet hibás a történtekben ha rossz esetleg,vagy a nagyfesz trafó?,ha valaki tapasztalt már hasonlót és esetleg meg is oldotta a hibát akkor megköszönném ha adna valami konkrét tanácsot.Még van egy végfokom mert kettőt vettem,de már nem akarok bajlódni sokat vele,ha most beleteszem az is elszáll...
Előre is köszönöm!
Ismét segítséget kérnék tőletek ez úton.
A nevezett készülék alaplaphibás volt ,rendeltünk is bele a SONY által javasolt mainboardot.Beleépítve ,valamint a gyári softwert ráfuttatva a jelenség a következő:be lehet kapcsolni,ki is de a képernyő sötét.Service menübe belépve hallani a hangszóróból ,hogy reagál a lépésekre de mivel semmit sem látni nem folytattam.A mai nap uj tconnal is a helyzet változatlan.A tápon a pfc ok,a tápok a 3,3v ,ill . a 12V úgy szintén.A LED driver bekapcsolt állapotban 42V-t kap ,ez a bekapcsolásnál sem ugrik feljebb,amit keveslek.Rávilágítva a kijelzőre inkább sakktáblaszerű mintázat látszik.Hibakódot nem villog a készülék.Kikapcsolásnál egy pillanatra felvillan láthatóan a háttér.Ha rossz lenne a led driver akkor hibakódot kellene villognia tudtommal.
Létezhet nem jó az új alaplap,már másra nem tudok gondolni.A Sony ajánlotta hozzá,de a szitázott számok mégsem egyeznek az eredetiével se a QR kód.
Kérném szíves segítségeteket.
Lajos
