SONY SA-WP780 VER.1.5
979.6 KB
SONY SA-WP780 VER.1.5 service manual (1st page)
Preview of SONY SA-WP780 VER.1.5 [1st page]
SONY SA-WP780 VER.1.5 service manual (2nd page)
Preview of SONY SA-WP780 VER.1.5 [2nd page]
    SONY SAWP-780 SAWP780 SAWP 780 SA WP780 SA-WP780
Sony STR-DE 225 Receiver, sudden interruption of Audio, after switching off everything is ok again
Hello, I got a problem with my Sony Receiver STR-DE 225.
There´s a sudden interruption of Audio in non defined intervalls - may be once ore 6 times during appr. 5hrs operation.
Interruption does not depend on Volume. Connection cables and speakers I´ve checked.
There´s a loud crack in both speakers, display shows for short time "PROTECTION".
After switching off and on again, everything operates normal until next interruption.
I removed from the inside of the receiver a lot of dust with a vacuum cleaner, but this didn´t help.
Unfortunately Sony has no documents for this device, as it is To "old" (1996), or could give me a hint,
in what cases "PROTECTION" might appear.
Is there anyone to give me a clue?  Thanks
Sony TA-F6B erősítő PLPS tápegység probléma
Egy 1979-es Sony erositot javitok, aminek a tapjaban ket kondenzator elfarad(kinyilt, C604/C606), magaval rantott par dolgot. Ennek egy korai kapcsolouzemu tapegysege van (a Sony Pulse Locked Power Supply-nak hivja), ami baromi erzekeny az alkatreszekre. Sajnos(vagy szerencsere csak) 3 tranzisztor megadta magat, ennek a helyettesiteseben kernek segitseget.
Q613 - 2SC2023 R TO220
Q602 - 2SC1810 TO202
Q603 - 2SA911 TO5
A regulator reszbol egyedul a Q601 (2SC2023R) es a Q604(2SC1810) maradt eppen, de gondolom a Q601/Q613 es Q603/Q604-et ugyis parban kellene cserelnem.
Helyettesito tranzisztort keresnek, ami elerheto akar itthon is. A 2SA911-en kivul a tobbi tranzisztor tokozasa jo lenne ha hasonlo/azonos lenne, mert hutobordara szerelt.
A 2SC2023-nal ki van emelve kulon, hogy a regulatornal R-es az inverter fokozatnal R vagy O-s jelolesut kell hasznalni.
A tobbi resze nagyjabol rendben van a panelnek(tobbi tranzisztor OK), minden elko uj, meg azt a par diodat es ellenallast fogom megmerni, de elso blikkre masnak nincs baja.
Sima 2SC2023 van itthon par darab, ami zavar hogy eredeti doksit nem talaltam hogy pontosan miven ter el a sima, R es O valtozat(gondolom hfe es frekvencia)
De a manualban ki van emelve, hogy az inverternel R es O lehet osszevalogatva, a regulatornal R.
Sima 2023-as nem jo(zarojelbe rakjak amivel nem lehet helyettesiteni)
Sony STR-VX30L erősitő
Üdv! Keresem a fenti erősitő rajzát. Köszönöm! sanyika45
Sony STR-434L rádió-erősítő rádiója néma. MEGOLDVA :)
Sziasztok! Adott a fent említett erősítő. 1979-1980 körüli gyártású, kívülről egészen jó állapotban van. Belül, ahogy nézem, még nem nyúlt bele előttem senki. Én eddig 2db nagy pufferkondit cseréltem a fő táprészben. Szépen szól a TAPE 1 és 2 bemenetekről, viszont ha rádióra kapcsolom, ott nem ad hangot. A hangerőt feltekerve mély alap-búgás hallatszik csak, ami elég brumm szerű. A frekvenciamérője valótlan értékeket mutat, ahogy tekerem a keresőjét, bár ez beállítható. Itt a tanyán megtaláltam a service manualját a készüléknek, de sokkal előrébb nem jutottam vele. Kiszáradt, vagy erősen kapacitás-vesztett elkóra gyanakszok. Találkoztatok már ilyennel? Update1: Tápok rendben, FR201 és 202 cseréje után az IC201 feszültségei megvannak. A gond annyi, hogy a service manual szerinti feszültségek közül rendre az AM üzemhez tartozó értékek vannak jelen, hiába van a sávválasztó tekerő FM állásban. A képen a normál zárójelben lévők lennének az FM üzem értékei. Előbbi tekerős kapcsoló nem direkt kapcsolja a feszültségeket, hanem PNP tranzisztorokkal, ezek között is találtam hibásat, zárlatosat. A rosszakat cseréltem. Tegnap pár másodpercre megjött a hang FM-en, de nem tudom mitől, visszahozni nem tudtam.
