STANDARD-NEGYESSZUPER EKA-436 CSOVES RADIO.
30.8 KB
Looking for similar standard manual?
    EKA-436 RADIO. EKA436 CSOVES EKA 436 STANDARD
ONKYO TX-DS494 low volume problem solving experience
Hello. here is a message to share my experience in solving a problem that appeared on the home-cinema amplifier ONKYO tx-DS494. In order to sell this amplifier I had to check if all the outputs and all the functions works properly. On the back of this amplifier you have to frontal output : A and B. I connect a pair of speaker on A output : no problem. I can adjust volume. when i connect the pair to the b output and turn the volume knob no sound came out of the speakers until I reach a level defined by I don't know what. :hmmm: My volume level goes from 0 to 80db ( if I remember well ). from 0 to 23 db no sound and when I reach 24 dn sound increase and stabilize. With hearphone connected, i don' have this problem so I conculde that amplifing transistor could not be incriminated. I checked on the service manual and saw that there are two or three component that could be the source of the problem : the main processor, some capacitors on the output PCB and relays. I began testing capacitors: no pb. then I thought that if cannot be the main proc because it ( I think ) works in a binary mode: it works or it doesn't. so I decided to switch between themselves the two relay and :super: : it works. The relays was in fault and did not switches properly. here is my experience in repairing an amplifier
Philips AQ5150/00S rádiómagnetofon hibás a CXA1538M SMD IC, véleményt kérek. Megoldódott.
Szevasztok! A felvetésem inkább csak költői kérdés jellegű, hiszen a CXA1538M SMD IC a SINI-nél 8586Ft. Meg ugye az utánvétes postadíj. Rajzom, persze nincs hozzá, de van az IC-hez adatlap. A hiba: A Vcc (Pin7) a testre 10R-t mutat a multiméterrel, miután kivettem az R12 68R előtét ellenállást. Az R12-re beérkező feszültség amikor az R12 ki van véve 6.27V. Visszatéve az R12-őt a Pin7-en 0.53V van jelen, eközben az R12-őn 5.73V, ebből adódóan a Pin7-re 84.2mA folyik. Ez az áram 8.5mA (AM), illetve 11mA (FM) lehetne az adatlap szerint. Esetleg nem túl szerencsés ez a konstrukció? Hiszen ez az IC elvileg nemigen hibásodhatna meg. Volt már valakinek a CXA1538M SMD IC-vel ehhez hasonlítható meghibásodása? Köszi!
Sony CDX-M850MP
Keresnék megvételre, a fenti autós CD-hez távirányítót, és előlap keretet. Tudom, hogy rendelhető, de túl sokat nem költenék rá. Saját készülékem, és most cseréltem benne szallagkábelt, ezért használt, vagy hibás érdekelne.
Clarion CV99B Kódot kér.
Sziasztok Fenti 1 lemezes régi nissan cd tár kódot kér. Van esetleg hozzá kalkulátor? Gyári számot még megtudakolom. Előre is köszi.
