SUPER UE 14-20-21 SM
391.2 KB
Looking for similar super manual?
SUPER UE 14-20-21 SM service manual (1st page)
Preview of SUPER UE 14-20-21 SM [1st page]
SUPER UE 14-20-21 SM service manual (2nd page)
Preview of SUPER UE 14-20-21 SM [2nd page]
    SUPER UE 142021 14 20 21 14-20-21
Super Star SF312 tv átalakítás
Helló szakik !!
Van egy régi Super Star SF312 computer technic TV, amire egy videó és egy audió bemenetet szeretnék tenni. Ehhez szeretnék segítséget kérni.
Előre is köszönöm.
Üdv. : Zomby
Olvastad?
Válaszd ki a megfelelő fórumot majd adj neki címet és írd be a kérdésed.
Akkor jó. Tegyél is úgy!
A kérdésedre a válasz: kénytelen vagy kivárni, amíg a moderátor tud foglalkozni a topikoddal.
Grundig CUC120 - Super Color A 7100 - CRT TV - Screen - Cinesc. is black
UPDATE: Note: This Model and CUC220, CUC720 almost identical My family b. this TV in 80' And worked ~15 years In 90' Black screen ... with Pot. in 100% Brightness, Contrast. In the end 90' puff doesn't work at all. Someone try repair but ... the same black screen. They reported ... try fix and get > Brightness In past 6 months, I repaired and new life come from the set, but now we get too much Brightness In your opinion ... the person try Adjust ... fix what? ABL - Automatic Brightness Limiter setup, regul.? R2533 R2538? Thank you for your comments, info. Ruy Please your comments: Brightness and Colour Pot. -> OK But Contrast Pot.: I can' rise ... NO FOCUS and washed out -> I only see a Blank RASTER. Best Regards, Ruy
__________________________________________________________________________________ ORIGINAL / PAST MSG Hi,
Super Color A 7100
The other sub-models in pag.1 - pdf
right bottom
elektrotanya.com/grundig_cuc120.pdf/download.html
The screen is black ... and we notice from time to time (when the image is very brig.) some small part of image.
Very few dots.
I tested the G1 2X V, G2 5XX V, Heather - G and J Volts in the neck of Cinesc.
Power Supply I tested +A 115 V, +C 200 V , +B 12V, +M 19V
In Pag. 6 - SSB and SB?         T2533
Thank you,
Ruy __________________________________________________________________________ Work with servers - OpenBSD, NetBSD, FreeBSD, Linux. Love Oscilloscope :-) , Repair, Satellite Dish, Multimeters. Have a Big Satellite Dish farm.
Grundig super color magyar használati utasítás
Üdv mindenki Lenne egy kérésem .Grundig super color tv-hez kellene magyar nyelvű használati leírás.Ez egy idős néninek kellene. Gondolom rázós kérdés kérés! Lehet PDF JPG formátum.Akár weboldal is. Köszi a segítséget. Üdv János
Grundig super color
Sziasztok lenne egy nem mai grundig super color c 3304 tipusú készülékem na most ez a készülék olyanokat csinál hogy a bekapcsoló gomb megnyomására nem mindíg kapcsol be rendesen sokszor csak a vezérlő részénél megjelenik a csatorna ha be is kapcsol akkor a baloldalon van kb egy 10cm-es zavaros csík.Valamint hol szines hol fekete fehér.Kérem akinek van ötlete vagy találkozott már ilyennel segítsen
