SUPRA SDV-601U SCH
CAR-AUDIO - SERVICE MANUAL
2.4 MB
CAR-AUDIO
Looking for similar supra manual?
SUPRA SDV-601U SCH service manual (1st page)
Preview of SUPRA SDV-601U SCH [1st page]
SUPRA SDV-601U SCH service manual (2nd page)
Preview of SUPRA SDV-601U SCH [2nd page]
    SUPRA SDV-601U SDV601U SDV 601 601U
Blaupunkt Peugeot T1 autórádió kód Megoldódot
Sziasztok! Blaupunkt PEUGEOT T1 LOW autórádió kódja kellene a szomszédom akut cserélt és nem tudja a rádió kódját. Próbálkozott és már ERROR 2 ír ki a rádió. Gysz: BP8140W1571316 Ha valaki tud segíteni köszönettel vennénk. Üdv Csaba
Becker Cascade BE7944 need help!
Hello to everyone!
Thanks in advance if someone can help)
I have a problem with replacement of malfunctioned final amplifier at Cascade BE7944.
It is play sounds through front loudspeakers with distortion.
It is not a problem with wires (I have tested it them with ohmmeter) and loudspeakers (brand new).
I have replaced with Traffic pro and it worked fine.
Radioengineer has announced the verdict - problem with final amplifier and it is must be replaced, and preferably with service manual or schematic, which I do not have. And I did not allow him to unassemble my Becker just "for to watch how it is looks from inside")
The problem is following:
1. Do someone have and can share with me with service manual or schematic of Becker Cascade BE7944.
2. As far as I understand BE7944 is further development of schematic Audio 10 ECE Typ 6011 (or 4011), which service manual is available at Internet - can I use it as general background for BE7944?
3. At present time unfortunately there is no possibility to find original MLT TDA 7454, only CHN or unnamed versions. I do not want to install that, but according to datasheet for TDA 7454 it can be replaced with TDA 738 *. And TDA738 * can be raplaced with TDA 7560 or TDA 7850 (in my case TDA 7851 L). If it is possible to replace TDA 7454 with TDA 7851 L and with which modifications? And will I not lose the “Backer surround” function?
4. Any other suggestions? Please withought "sell this dinosaur"
 I have written to Harman / Becker with this problem but still no answer ...
Thanks to all!
Elektret miokrofon jelének növelése
Autórádió mikrofonbemenet, üresjáratban 8V, 1k-val terhelve 4,5V mérhető rajta. Sima elektret mikrofon szól róla, de nagyon halkan, vonalszintű jelről már jó. Hogy lehet erősíteni a mikrofon jelét, hogy ne kelljen külön táp neki?
Jácint
Kenwood KDC-BT45U autórádió JCV8034 4x50W végfok IC miért mehetett tönkre? MEGOLDVA!
Egy 2016-ban vásárolt Kenwood autórádióban van ez az IC. A rádiónak minden része működik, csak hang nem jön ki belőle. Megbontást követően készítettem a csatolt képeket.
Nincs túl sok autórádiójavítási gyakorlatom, de azért láttam már pár esetet, ilyet még nem, hogy csak ennek az IC-nek a lábait elkorrodálta valami az alkatrész oldalon (forrasztási oldalon
semmi nyoma) letisztítva a korróziós lerakódásokat látható egy láb teljesen eltűnt egy másik jelentősen elvékonyodott az erről szóló képen sárgával bekarikáztam őket.(Ezen a két lábon kapja az IC a tápfeszültséget). A leírtakról csatoltam 4 képet. Két kérdésben számítok szíves, tapasztalataitokon alapuló segítségetekre:
1.) Nem tudom mi okozta a korróziót, de valószínűsíthetően a tápfesz láb elfogyása miatt nem működik a végfok. Van ötletetek, hogy mi okoz ilyen jellegű korróziót autórádióban és miért csak ennek az IC-nek az alkatrész oldalán?
2.) Beszereztek nekem valahonnan távolkeletről helyettesítő TDA7850A IC-t, mennyi az esélye, hogy azzal működni fog? Utóbbi időben itt is olvastam ezek megbízhatatlanságáról (ehhez annyit, hogy az eredeti címben szereplő IC gyakorlatilag beszerezhetetlen, illetve egy 40 ezres rádióra nyilván nem költ tízezreket az ember hogy hátha megtudja javítani.
Különösen, hogy ingyen segítségképpen foglalkozom vele, a rádió egy kollégámé).
Szíves segítségeteket előre is köszönöm. Üdvözlettel: Csolo2 (alias Laci)
