I have a Yamaha CDX-590 CD player and it skips on some CDs - original CDs, these CDs play without problems on my other CD players.
I have changed the laser unit (KSS-210A) but this didn't solve the problem.
When I turn the player upside down, it plays the problematic CDs without a problem.
That's why I think the laser needs adjustment.
I have only a service manual for the CDX-493/593 but they should be very similar to the CDX-590.
It seems that the adjustments are done via "test mode" of the CDX-590, unfortunately there is not much information, how to exactly, in the service manual.
Here is a picture of the PCB.
http://www.volny.cz/hwtest/PCB.JPG
Here are the "test mode" sections of the service manual.
http://www.volny.cz/hwtest/TM1.GIF
http://www.volny.cz/hwtest/TM2.GIF
In "test mode" I have tried Auto adjustment mode 1, 2, 3, but I don't know if it should work fully automatic without any intervention or when the mode is fineshed and I can proceed to the next one.
So I activated mode 1, waited a while, activated mode 2, waited a while, activated mode 3, then exited test mode.
It didn't help.
Mode 1 - only a short blink of two horizontal dashes on the display and thats it
Mode 2 - started "play" without sound from a strange time 99:00 (the test CD is not so long), after a while it skips to another time, "plays" a while, then skips back and "plays" and so on, I left it about an hour and it was still going on
Mode 3 - seems to be very short as mode 1
I think I'm missing something ...
Maybe someone did this or even serviced Yamahas in an official service and can provide information how to adjust the laser?
Or maybe the problem is not the laser?
Sziasztok, jó estét Mindenkinek!
Kérek szépen egy kis segítséget, hátha valaki már találkozott hasonló hibával. A címbéli KRF-V5030D tip. erősítő előlapján a nyomógombok nem működnek. De csak a gombok; a hangerő szabályozó és a funkcióváltó encoder működik, valamint a távirányítóval minden működtethető. (Esetleg a távval nem lehet a frontpanel gombjait hatástalanítani?? Sajnos nincs hozzá magyar nyelvű kezelési könyvem.) A panelt nagyjából átnéztem, a 0,047F-os kondit kicseréltem, mert kicsit mintha ki lett volna folyva és félig rozsdás is volt, találtam egy forrasztási KH-t is, de a gombok ettől még nem éledtek fel. Valaki találkozott már hasonlóval?
Előre is köszönöm Mindenkinek, aki segíteni tud.
Üdv: pianista
Kerult hozzam egy SENZ markaju Bluetooth hangfal.
A gyari cimke le van tepve rola.
Eleg nagy, vagy 60 cm magas, ket 16 centis hangszoro van benne es egy eleg nagy (nem szereltem ki, hogy megnezzem a kapacitasat), 12V akku. Korulbelul egy eves keszulek, nyilvan nincs ervenyesitheto garanciaja.
Ugy tunik, hogy a
KP686T tipus ujra-brandelese.
Bekapcsolaskor enyhe nyoszorges hallatszik a hangszorokbol, de semmi sem vilagit, az amugy nagyon diszes kezelo lapon.
Szetszedve arra jottem ra, hogy hianyzik az 5V es a 8V.
Ez a panel allitja elo.
Megkapja a tapot a jobb also csatlakozon, VCC neven de semmi mas feszultseg nincs rajta.
Azonosithato ket stabilizator, IC13 es IC14, ezek 7805 es 7808, de nem kapjak meg a tapot. A soros ellenallasok (R266 es R122) elott sincs meg a tap.
Van meg egy stabilizator, az U1, a kepen a jobb also sarokban, ennek a modellje TD1509P5, ez is 5v SMD stabilizator, de szinten nem kap tapot.
Az egyetlen alkatresz amit azonositottam, hogy rajta volt a tap es kollektora kozos a 3 stabilizator bemenetezvel, az a Q14 tranzisztor, A77E jelolessel.
Ezzel csak a kovetkezo ket bajom van:
Nincs megnyitva (bazis-emitter feszultseg nulla)
Tul kis teljesitmenyu, ahhoz, hogy ez kapcsolja az egesz fogyasztast. Csomo led van a lapon, kijelzo, stb, szoval en kizartnak tartom.
Jaj igen, a ket USB hasznalhato telefon toltesre is. Hogy leellenorizzem a feszultseget, radugtam egy USB fogyasztasmerot ami kijelzi a feszultseget es a felvett aramot.
Ez vilagitott es kijelezte a 5.18V feszultseget. Par masodperc mulva kialudt, majd megint bekapcsolt, es igy tovabb ciklikusan. Ezen tehat van (neha) feszultseg.
Ugy nezem, ugyanez a hangfal futott Toshiba TY-ASC65 nev alatt is.
Tudom, hogy igy nagyon nehez, de folytatom a bogaraszast, ha valakinek otlete van.
Elore is koszonom a velemenyeket.
Minden jot,
Janos
Tisztelt Szakik!
A hibajelenség hogy üzem közben mélyhangú gerjedés hallható bemenő jeltől függetlenül! Ami kb 1 másodpercenként hallható (beep-beep ritmusú) és olyan mély frekin ami akkor hallható amikor ujjal hozzáérünk a bemenethez.
A készülék TDA2005 végfokkal szerelt ami 20W-os(méghogy 120W :)) és ez duplán(sztereó) mindkét végfokból hallható, ha állítom a bemeneti mély hangszínszabályzást akkor arra reagál-erősödik ill gyengül a búgás.
Tranyók rendben.
Kondikat még nem néztem, előéletről még érdeklődnöm kell, csak a tulaj "hibbant", már a kérdést se érti.
Esetleg kapásból végfok IC csere?
Köszönettel D Attila
