THE HARMAN KARDON HD720
5.1 MB
Looking for similar the manual?
THE HARMAN KARDON HD720 service manual (1st page)
Preview of THE HARMAN KARDON HD720 [1st page]
THE HARMAN KARDON HD720 service manual (2nd page)
Preview of THE HARMAN KARDON HD720 [2nd page]
    THE HARMAN KARDON HD-720 HD720 HD 720
Trio-Kenwood: KR-3010 [Radio] S.N.962845 / Does not work, the final floor and prefinal floor defect with many burned component/
I greet you! I would need the scheme of this "vintage" amplifier that needs to be "restored". The problem is that in the prefinal and final floor I have many "fried" resistors well, their value cannot be identified.I replaced the defective transistors: 2SC1509, 2SA777,2SB690 and 2SD 796 (each 2 pcs.) and the electrolytic capacitors adjacent to them. I could not go further because of the carbonized resistors that I do not know their value (I can only guess that they are values small, in the order of ohms). The schematic diagram I downloaded, from the address received by the kindness of a colleague is not complete - it is a single page (missing Q29-Q30-Q31-Q3 and resistors R115-R116-R117-R118 which are completely carbonized, at other resistors I could see their value).Thanks in advance!
Finally, I found the missing part
If stuck in the repair and you ask questions, please do it as follows: - Details: Give the exact model number of your device and the chassis ID (if there is). - If possible, please attach pictures of the appliance. - Anamnesis: Write down the exact symptom. If hard to describe the symptom, it is difficult to verbally defined clearly, attach pictures or sound of the phenomenon! - Tell what was you have done so far: search contact error, which parts has examined or changed yet, etc... The incorrectly named topic suspended and will be deleted after 48 hours! Suspended state while others are not able to comment until you correct the address. Subsequent repair of the defective title (within 48 hours) by clicking on the "Edit" tab can be carried out.
Aiwa RX-30 -ban a 3SK73 helyettesíthető-e BF964-el? És hangolási hiba.
Sziasztok! Egy Aiwa RX-30-at javítok, tuner-hibás. A 3sk73-ra terelődött a gyanú. Az volna a kérdésem, mivel semmit nem találtam róla, hogy helyettesíthető-e pl. BF964, vagy BF966-al? Persze, megfelelő lábelrendezés után. Köszönettel Attila
I want upload a service manual and the page don't allow me
The file is: marantz_pm493.pdf And I put under: audio, power amplifier, service manual The forums not are in English, I don't understand the titles and I can not traslate
JVC DX-MX70BK időnként vagy testhez érintett tetővel lekapcsol (jegelve)
Szervusztok!
DX-MX70BK torony két egységét, az AX-MX70BK és FX-MX70BK tesztelve - ritka, véletlenszerű lekapcsolás okán – számomra ismeretlen, furcsa tapasztalásom van.
Túl azon, hogy ritkán és véletlenszerűen lekapcsol, ez a lekapcsolás oly’ módon is előidézhető, hogy bármely egység tetejét megpróbálom rátenni vagy levenni, de elég akár a tető valamely pontjának testponthoz érintése. Ezt „tudja” bekapcsolt és készenléti állapotban is. Az erősítő egység teljesen kuka lesz, a kijelző és egyéb jelzőfények elsötétülnek. A rádió egységen a kijelzés és minden funkció továbbra is működik. Kisebb fémtárgyakra (csavarhúzó, szigeteletlen csipesz) mechanikai hatásokra nem reagál. Mintha kapacitásfüggő lenne. A normál üzem helyreállítása csak a tápfeszültség  le és némi idő múltával annak visszakapcsolásával lehetséges. Ilyenkor ott folytatja ahol abbahagyta.
Lévén szerencsém az összes egyéb panel cseréjére, maradt az analóg kapcsoló és erősítő panel (ENH-177-1) gyanúsítása, de csak állok a készülék mellett bután, mint propán.
A jelenségről készítettem rövidke mozgóképes dokumentumokat.  1 2 3
Szerviz manó itt
Számítva érdemi segítségetekre üdv, Bencsik
Úgy döntöttem, hogy most egy kicsit félreteszem, mert lehet, hogy rossz irányba haladok.
Mindenkinek köszönöm segítő szándékát!
Bencsik
