XORO HSD400PRO [MAS89 MODIFI1]
VIDEO-DVD - EPROM
702.1 KB
EPROM
Looking for similar xoro manual?
    XORO HSD-400PRO [MAS-89 HSD400PRO [MAS89 MODIFI1] HSD 400 PRO [MAS 89 MODIFI
Sony Sl-S770 vcr interrupted playback and AV display issues
I'm encountering an issue with my Super Betamax player. During playback, some cassettes abruptly stop playing at seemingly random points, accompanied by a sound similar to the one made when a tape reaches its end. This interruption also renders the rewind and forward buttons unresponsive. However, it does not impede the manual forwarding or rewinding of the cassette. The only solution seems to be ejecting the cassette and reinserting it. Occasionally, even this workaround fails, allowing only two seconds of playback before the problem recurs.
I sought guidance from the Mister Betamax troubleshooting page, which indicated that the tape safety device might be the root cause. I received additional advice suggesting that the issue could stem from one of the sensors within the VCR, possibly due to oxidized contacts causing intermittent operation. It was recommended to resolve this by carefully cleaning the contacts on the sensor switch responsible for detecting loaded tapes or the sensor that detects if the tape is "record-protected." Another suggestion was to monitor the output of these switches using an oscilloscope or voltmeter to determine if they are indeed the source of the problem.
I'm eager to hear if anyone has additional advice or personal experiences to share regarding this issue.
Additionally, I'm facing an AV cable problem where the yellow AV cable fails to display any video. While it used to work correctly, the AV audio cable still functions properly. As a temporary workaround, I've been using a coaxial cable and routing it through another VCR to utilize its AV output. However, I'm interested in exploring potential solutions to fix the issue with the yellow AV cable, if possible. Any insights or suggestions would be greatly appreciated.
HITACHI VT-S80E bekapcsolást követően kikapcsol.
Üdvözlet Mindenkinek! A fentebb jelzett videomagnót a hálózati kapcsolóval bekapcsolva a készülék néhány másodperc múlva kikapcsol,közben más életjelet nem ad.Sajnos a Tanyán nincs hozzá semilyen adat, és másutt sem találtam, ezért első sorban azt kérném,a kapcsolási rajz megszezésében segítset,hogy a tápfeszültségeket tisztázni tudjam. irokéz
Bellagio AD2020 DVD nincs bejelentkező kép
Sziasztok! Bellagio AD 2020-as asztali DVD lejátszón nincs kép egyik kimeneten sem. Tápfeszültségek rendben,laser egység cserélve lett mert nem olvasott be semmit. Most beolvas mindent, de kép nincs. Merre induljak? Köszi Pali "FONTOS! Olyan fórum téma nevet válassz, ami beszédes, minél pontosabban illeszkedik arra, amivel kapcsolatban írsz. Egy lehetséges jó elnevezés pl: ORION LCD PT26S chassis 17MB12-2, a tápja nem indul Az nem elég, hogy pl: "LG LCD-TV" vagy "HP laptop" és hasonlóak. Illetve érdektelen, nem releváns információt se tartalmazzon a cím! A helytelenül elnevezett topik felfüggesztésre, majd 48 óra után törlésre kerül! Felfüggesztett állapotban nem tudnak mások addig hozzászólni, amíg ki nem javítod a címet. A hibás cím utólagos javítása (48 órán belül) a "Szerkesztés" fülre kattintva végezhető el."
Panasonic NV-HS950 műhiba
Üdv! Sikerült kivégeznem a gépet, az alaphiba a betöltő motor tengelyén lévő műanyagidom elrepedése volt, rutinműtét-megragaszt-összerak-lepróbál minden ok csak lejárt a munkaidő igy nem raktam rá a fedelet. Másnap reggel mégegy rutinellenőrzés de a bekapcsoláskor berántotta a kazettát, jó gyorsan tekerte a szalagot, képet nem adott és nem reagált semmire, gondoltam talán a táp, előtte egy másiknál a tápkondizás előtt hasonló volt a jelenség, hajszárítót csak közelítettem a kondikhoz és helyre is állt, mig melegítettem minden funkció működött, kicsit gyanus volt, hogy mihelyt elvettem a hajszárítót vagy csak félrefordítottam azonnal kezdte a kavarást, tápot felkondiztam a helyzet ua. Átnéztem többször a mechanikát átforrasztottam az alaplemez kritikus részeit-optokat stb, hiba maradt. Egy hét mulva elővettem, a kavarás változóan de maradt, ujra szétszedtem többször, majd valaki becsukta a mögöttem lévő ajtót és a hiba megszünt... Kicsit megzavart hogy egy videóval sem jártam még úgy hogy az oldalról jövő fény /én a videó mögött szoktam ülni-állni tehát takarom az ajtó felől/ így átverjen és szerencsétlenségemre mindig akkor vettem elő amikor ezerrel sütött a nap és nyitva volt az ajtó. Lényeg hogy a mechanika helyreállt de kép nincs csak zaj, a hangot adja rendesen felvételnél veszi is, csatikat kábeleket kh-kat átnéztem,fejmagok nem sérültek és tiszták, fejerősítő modul az 5v-ot megkapja, ha a flexit kihúzom akkor is van hang csak tompább és halkabb ha valakinek volna ötlete szivesen fogadnám, elnézést a hosszú szövegért.
