Üdv' Mindenkinek. Lényegében dominó Whirlpool. Kijöttem, erre működik. "Megjavult".
Hello,
I have a washing machine (Bauknecht WAK74 (8583 642 03011) ) that had an F8 error due to a bad heating element. After changing it, the washing cycle (also the test program when hitting the "löschen" (delete) button a couple of times does more or less ) runs through, it is heating fine, but the F8 error is still being displayed.
I checked, cleaned, enhanced all the contacts, also of various other places I could reach to make sure it won't detect it e.g. due to vibration shortly causing a higher impedance.
I am a bit out of my comfort zone here (usually doing industrial stuff) so not having any experience with the brand and only service manuals from similar machines I am not quite sure if
- there is something else that could cause the F8 error that happened during the repair.
- there is a procedure needed to reset the error from the machine
- the error is really triggered each time the program (or test) runs, or if it is saved in the eeprom
Unfortunately I don't have a "clean" eeprom to just overwrite the old one. One test I did though was disconnect the NTC, leading to another error, then reconnecting it. The test program would still display the NTC error, but after writing back the old eeprom it didn't. So my suspicion is that the current eeprom might somehow contain the F8 error and overwriting it with a clean one might be all thats needed...
( I also grabbed the µC code and tried to disassemble/decompile it in ghidra but didn't have the time to get very far with it)
Némi megerősítés kéne,javítok egy Bauknecht_GCFP_4824_WH mosogatót fűtés hibával.
Az NTC szakadt ez biztos.
Találtam is egy hasonló whirlpoolba való holmit.
Orczyban
MHS709
Hőérzékelő (NTC) WHIRLPOOL mosogatógép
Viszont elég drága ahoz hogy berendeljem,aztán ha mégsem jó ..
Szóval kinézetre passzol, de a szervíz manual sem írja az értékét és itt sem szerepel a terméklapon.
Tehát a kérdés jó e vagy sem bele?
Esetleg bontott valakinél?
Van egy Bauknecht TK Plus 72A kondenzációs szárítógépünk hőszivattyúval.
Ugyanez van Whirlpoolban is.
Sajnos a program lefutása után, nedves marad benne a szarítandó ruha, a kondenzvíz tartály üres.
A kondenzszivattyút, a kondenzvíz vízszintérzékelőt megnéztem, jók.
Hibakódot nem ír ki.
A kompresszor forró, de lehet, hogy nem a kompresszor bekapcsolása után egyből, hanem ahogy jár a kompresszor, a működéstől.
Igazából én elszökött gázra gyanakodnék.
Honnan tudom, hogy ha kevés a rendszerben a gáz ?
Egy hűtőszerelő tudja, hogy mennyi gáz kell bele ? Esetleg a gáznyomásából tudja ? Ráadásul milyen gáz van bene ?
Ha elszökött a gáz, akkor a rendszer valahol lyukas.
Köszönöm
