BAUKNECHT GSUK 4507
DISHWASHER - SERVICE MANUAL
2.9 MB
DISHWASHER
Looking for similar bauknecht manual?
BAUKNECHT GSUK 4507 service manual (1st page)
Preview of BAUKNECHT GSUK 4507 [1st page]
BAUKNECHT GSUK 4507 service manual (2nd page)
Preview of BAUKNECHT GSUK 4507 [2nd page]
    BAUKNECHT GSUK 4507
Bauknecht WAK74 washing machine error F8 persisting after change of heating element.
Hello,
I have a washing machine (Bauknecht WAK74 (8583 642 03011) ) that had an F8 error due to a bad heating element. After changing it, the washing cycle (also the test program when hitting the "löschen" (delete) button a couple of times does more or less ) runs through, it is heating fine, but the F8 error is still being displayed.
I checked, cleaned, enhanced all the contacts, also of various other places I could reach to make sure it won't detect it e.g. due to vibration shortly causing a higher impedance.
I am a bit out of my comfort zone here (usually doing industrial stuff) so not having any experience with the brand and only service manuals from similar machines I am not quite sure if
  • there is something else that could cause the F8 error that happened during the repair.
  • there is a procedure needed to reset the error from the machine
  • the error is really triggered each time the program (or test) runs, or if it is saved in the eeprom
Unfortunately I don't have a "clean" eeprom to just overwrite the old one. One test I did though was disconnect the NTC, leading to another error, then reconnecting it. The test program would still display the NTC error, but after writing back the old eeprom it didn't. So my suspicion is that the current eeprom might somehow contain the F8 error and overwriting it with a clean one might be all thats needed...
( I also grabbed the µC code and tried to disassemble/decompile it in ghidra but didn't have the time to get very far with it)
Bauknecht BAR2 KH8V2 IN beépíthető sütő F24 hibakód
A fenti Whirpool gyártású beépíthető sütő csinálta a grimbuszt lányoméknál. Leveregette a Fi relét. Akkor a sütő izzónál volt valami gubanc a szerelő szerint. Ez egy új de csomagolás sérült termék. Most kiírt egy hibakódot aminek a javítási tétele 60000Ft. Találkozott már valaki ezzel a hibával, hogy mi okozza? Kód szerint túlmelegedés., de ezt hideg állapotban írja ki mikor beindítanád és persze nem is indul. Persze egy manuál is sokat segítene.
Mellékletben a belső cimke.
Ez a gép.
https://www.grx.hu/shop/haztartasi-nagygepek/beepitheto-sutok/bauknecht-bar2-kh8v2-in-beepitheto-suto
Bauknecht wa plus 622 slim sokáig mos
Szisztok! Bauknecht wa plus 622 slim sokáig mos. Valamiért folyamatosan "lefagy". Az idő jelzőn látható hogy ilyenkor nem villog a kettőspont az óra és perc között. Ilyenkor a fűtést is lekapcsolja. 10mp múlva újra indul a fűtés és a motor is kezdene hajtani, de újra megáll. Fűtőszál nem testzárlatos. Szerintetek? Üdv. G.
Bauknecht mosógép szivattyú
Üdv. Keresek 1 Bauknecht mosógéphez szivattyút. A gép típusát nem találtam rajta sehol, csak 1 számsort"8554.549.03100" Fotókat mellékelek az elejéről. Aki ismeri kérem segítsen. Attila
