Hello,
I have a washing machine (Bauknecht WAK74 (8583 642 03011) ) that had an F8 error due to a bad heating element. After changing it, the washing cycle (also the test program when hitting the "löschen" (delete) button a couple of times does more or less ) runs through, it is heating fine, but the F8 error is still being displayed.
I checked, cleaned, enhanced all the contacts, also of various other places I could reach to make sure it won't detect it e.g. due to vibration shortly causing a higher impedance.
I am a bit out of my comfort zone here (usually doing industrial stuff) so not having any experience with the brand and only service manuals from similar machines I am not quite sure if
- there is something else that could cause the F8 error that happened during the repair.
- there is a procedure needed to reset the error from the machine
- the error is really triggered each time the program (or test) runs, or if it is saved in the eeprom
Unfortunately I don't have a "clean" eeprom to just overwrite the old one. One test I did though was disconnect the NTC, leading to another error, then reconnecting it. The test program would still display the NTC error, but after writing back the old eeprom it didn't. So my suspicion is that the current eeprom might somehow contain the F8 error and overwriting it with a clean one might be all thats needed...
( I also grabbed the µC code and tried to disassemble/decompile it in ghidra but didn't have the time to get very far with it)
Údv. A kollégåknak!
Bauknecht WAK 7751 tipusu elöltöltős mosógéphez lenne szükségembeproom tartalomra 24c08 eproom van benne. Köszönöm a segítséget elöre is.
Sziasztok .Segítséget kérnék a mosógép javításához. Hiba jelenség, a mosás rendben elindul,ajtó lezár felveszi a vizet elindul a forgatás bekapcsol a fűtés majd a 9-10 perc mosás után kiáll f01 hibára.A mosógép bauknecht 7 kg EW7F4 tip. Minden programon ugyan az a jelenség.Amit eddig cseréltem motort ,elektronikában a motor triacot,és fűtőszálat.A fűtőszál csere után egy program (1 órás) végigment,de a következő mosásnál újból visszajött a hiba.Már nem tudom hogy mit csináljak még vele .köszönöm a segítséget
Nos, sokszor lehetett olvasni, hogy mosógépek fűtőszála gyakran felelős azért a jelenségért, hogy leveri a Fi relét.
De mi a helyzet a szárító gépekkel ?
Vajon ez esetben is erre felé kéne keresgélni ?
Szárítógépekről ilyen témában nem igazán találtam infót.
Keresgéltem a neten, de őszintén megmondva csak annyit találtam, hogy A típusú relét kell használni.
OK, rendben, de ez eddig működött.
A tulaj szerint leállt egy hibakóddal, azóta nem lehet elindítani sem.
Vajon fűtőszál hibakóddal állt le ?
Olyat már próbált valaki, hogy leválasztó trafóval indított el ilyen masinát ?
Hátha úgy kiírná a hibakódot.
Volt esetleg bárkinek dolga hasonló jelenséggel ?
Köszönöm, István.
