Hello,
I have a washing machine (Bauknecht WAK74 (8583 642 03011) ) that had an F8 error due to a bad heating element. After changing it, the washing cycle (also the test program when hitting the "löschen" (delete) button a couple of times does more or less ) runs through, it is heating fine, but the F8 error is still being displayed.
I checked, cleaned, enhanced all the contacts, also of various other places I could reach to make sure it won't detect it e.g. due to vibration shortly causing a higher impedance.
I am a bit out of my comfort zone here (usually doing industrial stuff) so not having any experience with the brand and only service manuals from similar machines I am not quite sure if
- there is something else that could cause the F8 error that happened during the repair.
- there is a procedure needed to reset the error from the machine
- the error is really triggered each time the program (or test) runs, or if it is saved in the eeprom
Unfortunately I don't have a "clean" eeprom to just overwrite the old one. One test I did though was disconnect the NTC, leading to another error, then reconnecting it. The test program would still display the NTC error, but after writing back the old eeprom it didn't. So my suspicion is that the current eeprom might somehow contain the F8 error and overwriting it with a clean one might be all thats needed...
( I also grabbed the µC code and tried to disassemble/decompile it in ghidra but didn't have the time to get very far with it)
Nos, sokszor lehetett olvasni, hogy mosógépek fűtőszála gyakran felelős azért a jelenségért, hogy leveri a Fi relét.
De mi a helyzet a szárító gépekkel ?
Vajon ez esetben is erre felé kéne keresgélni ?
Szárítógépekről ilyen témában nem igazán találtam infót.
Keresgéltem a neten, de őszintén megmondva csak annyit találtam, hogy A típusú relét kell használni.
OK, rendben, de ez eddig működött.
A tulaj szerint leállt egy hibakóddal, azóta nem lehet elindítani sem.
Vajon fűtőszál hibakóddal állt le ?
Olyat már próbált valaki, hogy leválasztó trafóval indított el ilyen masinát ?
Hátha úgy kiírná a hibakódot.
Volt esetleg bárkinek dolga hasonló jelenséggel ?
Köszönöm, István.
Némi megerősítés kéne,javítok egy Bauknecht_GCFP_4824_WH mosogatót fűtés hibával.
Az NTC szakadt ez biztos.
Találtam is egy hasonló whirlpoolba való holmit.
Orczyban
MHS709
Hőérzékelő (NTC) WHIRLPOOL mosogatógép
Viszont elég drága ahoz hogy berendeljem,aztán ha mégsem jó ..
Szóval kinézetre passzol, de a szervíz manual sem írja az értékét és itt sem szerepel a terméklapon.
Tehát a kérdés jó e vagy sem bele?
Esetleg bontott valakinél?
A címben szereplő mosógép motorvezérlő panelján elégett az R10-es és az R11-es ellenállás.
A színkódjuk olvashatatlan.
Arra kérnélek benneteket, ha valakinek van ilyen panelja legyen szíves megnézni az említett két ellenállás értékét.
Ha esetleg a panel kapcsolási rajza fellelhető valahol, azt is megköszönném.
A segítséget előre is köszönöm.
A panel adatai:
AKO 544 271
BHG
4619 710 63361
Üdv:Ladakölyök
Megoldás: A motorvezérlő panelon az R10,R11 13kOhm-os ellenállásokat cseréltem ki, valamint a motorra menő csatlakozót is cseréltem mert az egyik érintkező erősen patinás volt.
A motor szénkefevezetői is erősen patinások voltak, ráadásul az egyik kefe nagyon hosszú volt, a másik pedig csak jó ha a fele.
Ezért azokat is kicseréltem egyformára.
A motort a szénportól kifúvattam és megtisztítottam az érintkezőit is.
Az IGBT-re és a mellette lévő védődiódára hőpasztát kentem, mivel alig volt rajtuk és az R11-es ellenállás cseréjéhez le kellett vennem a hűtőbordát. Mivel a bordán kevés volt a paszta, így amikor a pántokkal hozzáfogattam az IGBT-t és a védődiódáját, akkor a gép nem tudta elindítani a motort, csak a relét kattogtatta és ki is állt F7 hibával.
A paszta pótlásával azonban a gép tökéletesen működik.
Még egy pár teleszkóp kell bele, mert azok is totál ki vannak menve, de ez már részletkérdés.Üdv:Ladakölyök
