Good morning, I have a Harman/Cardon AVR1510 receiver with the following defect. When I change the function it goes into mute, sometimes it plays back to normal or it takes time to release the audio, I would like some help to solve this problem. Thank you very much in advance.
For your information to repair
Harman KArdon HD710 Player uses a KSS210B Pickup (as spare, original unknown)
can be changed without any other servicing
Harman Kardon Receivers; Series AVR 2000,3000...
"Looses memory issue"- gold cap at the front pcb defective. May be changed to a 1µ cap but you have to solder 3 other elko´s to the other side. Keeps memory for a longer time.
"Hum noise for the first 5min, warm up" - right lower side at the main pcb: elko 7800µ dead- you can see it at the "cap of it". Replace both (7800µ and 2200µ) to new versions above 25V.
"Fuse burnt voltage selection; no green led´s flash, no sound"- cap 2200µ make a short circuit (next to 7800µ). Change these elkos! If you want to make it better... change the 7x 10µ caps for the regulators too. Resolder all points there.
"volume changes self to max. or min." change the two resistors at the front pcb close to the volume encounter. be sure that there are both sides 5V!
"everything is functional but no sound; but sound from the 6.1ch in" TC9273N-07 is dead (shorted). Have a look at the two caps and the security resistors beneath this chip! My be dead too. Replace this chip only by the -007 version. others will not function.
Be careful with the bigger stripe cable! the contact lines are loosen from the plastics. You can help yourself with a "second glue" under these contacts.
So i hope i can help you...
cheers SG.
Üdv. Mindenkinek!
A fent nevezett készülékbe sajnos a nyílásain keresztül bekerült a gyerekek által egy fém haj csatt. A probléma az lett, hogy bekapcsolás után 1mp-ig van "némi" hang, aztán teljes csend.
Ha ki- be kapcsolgatjuk mindig megszólal egy pillanatra. Sajnos fizikálisan semmi nem látszik, ami ki mérhető az talán rendben van. Túl sok a csipek száma, hogy fejből menjen. A csatlakozókról a jel megérkezik az ET9235 típusú elektronikus hangerőszabályzóra, de onnan tovább nincs jel. Vagy teljes "MUTE" állapot keletkezett, vagy valamelyik IC tönkre ment. Oszcilloszkóppal próbáltam követni a színusz útját, de ET-nél megáll minden. Processzor, vagy programozott alkatrész nincs benne, de nem ismertem fel, hogy ET hogyan vezérlődik... CMOS TTL is van egy garmadával. A hangerő szabályzására egy monó poti szolgál, gondolom egyenfeszültséggel szabályozna, de nincs egyik lábán sem mérhető feszültség..
Keresek némi infót, doksit.
A címben említett erősítő tápja azt produkálja, hogy a STB 5V pulzál rajta, ha a front panel csatlakoztatva van, akkor a power led jól mutatja a jelenséget. Nem védelmi módban van, hanem tényleg mérve is, mászkál a táp folyamatosan 2-5V közt. Elkók esr-re, kapacitásra jók. TF91 trafó és az IC91 névre hallgató pwm contorller is jó. Aki esetleg javította ezt a kapcsolóüzemű tápot, adhatna pár tanácsot, mert ezekben nem nagyon vagyok otthon...
Üdv.: Viktor
A hibát az IC92 pwm kontroller okozta, de jól meg is szívatott mert rendeltem a HQ-tól, még szerencse, hogy 2 db-ot, persze amit elsőre beforrasztottam halott volt, és el vitte magával az IC91-et is. Mindkettő cseréje után a táp elindult.
