Hello,
Last week I picked up a nice Kenwood KA-3500 40watt intergrated amplifier in pretty good shape.
Upon using it a bit more, I noticed a bit of distortion at high volume, more so in the left channel. I checked the DC offset at the speaker terminals, and the L channel said 100 mV, while the R was 25 mV. I understand this isn't so good for the L channel at least, but unfortunately this amp doesn't have any DC offset adjustments. Am I right in saying that to fix this I'd have to replace the output transistors?
On a related issue, in the service manual I found the section on BIAS adjustment, and I read online how it can affect the DC offset. So I hooked up my voltmeter to the test points, and I got 4 mV on the L, and 8 mV on the R. In the manual it says should be 40 mV.....(!). Is there something wrong here? I tried carefully adjusting them, but they only go to 30mV with the pots fully on, this doesn't seem right to me.
I compromised at 20 mV BIAS for both channels, and now the DC offset is 50 mV for L, and 5 mV for R, which is better, less than half what they were. I'm wondering, will I damage anything doing this, should I put them back to where they were?
The service manual is on site here.
Let me know if you want me to upload an english copy of the Owner's Manual, it has a better schematic in it all on one page, easier to read.
I've also included some pictures. They're not my actual unit, but mine is exactly the same, but less dusty.
Thanks for reading this. Many thanks in advance, and have a peaceful Palm Sunday! :taps2:
Bellarmine
Nevezett házimozi erősítő hibásan került hozzám, bekapcsolás után pár másodperc múlva kikapcsolt és villogott a standby LED.
Két hibrid végfok van benne STK 442-070 és STK 443-070, kivettem őket és az utóbbit mérések alapján hibásnak találtam.
Megrendeltem az újat, kicseréltem és összeraktam az erősítőt, tehát a hátlap felrakva és az összes csavar benne.
A jelenség annyit változott hogy most már nem kapcsol ki és szerintem minden funkciója állítható, de a hangfalakból csak halk sistergés hallható, ja és a tuner keresője sem áll meg autómata kereséskor. Próbáltam külső jelforrásról is de így is néma.
A végfokok hűtőbordáján van két fesz.stabilizátor 7912 és 7812, ezeken a feszültségek rendben vannak, kis értékű ellenállásokat átnéztem nem szakadtak és zárlatot sem találtam.
Összerakva elég körülményes a méregetés benne a panelek elrendezése miatt.
Ehhez kérném a segítségeteket, mi okozhatja ezt a hibát? Mit kellene alaposabban átnéznem?
Tisztelt Szakik!
Egy ismerősöm fordult hozzám ezzel a kéréssel, hogy milyen módon (módokon) lehet ezt itthon beüzemelni.
Kiindulási alap hogy a legegyszerűbben és a legolcsóbban.(meg persze legyen üzembiztos)
Ehhez kérnék tippeket.
Amerikai eredetű készülék, 120V 60Hz, rajza a itt a tanyán, 13 oldal a táp rész.
Köszönettel D A
A fentnevezett rádiót nemrég hibásan kaptam.
A Tanyán található Kenwood KR-A47 rajz alapján,sikerült megjavítani,hiányzott a +14V.
A rajz nem pontosan ezé a rádióé, de az erősítő és a táp ugyan az.
Szépen szól az erősítő, és a rádió jó érzékenységű szerkezet.
Egyetlen hibája hogy kikapcsolás után, kb. egy óra hosszáig tartja meg a memóriába beállított frekvenciákat.
Mivel elemet vagy akkut sem a rajzon sem a rádióban nem találtam,kapacitását elveszített kondenzátorra gondolok,de nem tudom melyik lehet.
Ebben kérném hozzáértők segítségét.
Előre is köszönöm.
Laci.
