Hello,
Last week I picked up a nice Kenwood KA-3500 40watt intergrated amplifier in pretty good shape.
Upon using it a bit more, I noticed a bit of distortion at high volume, more so in the left channel. I checked the DC offset at the speaker terminals, and the L channel said 100 mV, while the R was 25 mV. I understand this isn't so good for the L channel at least, but unfortunately this amp doesn't have any DC offset adjustments. Am I right in saying that to fix this I'd have to replace the output transistors?
On a related issue, in the service manual I found the section on BIAS adjustment, and I read online how it can affect the DC offset. So I hooked up my voltmeter to the test points, and I got 4 mV on the L, and 8 mV on the R. In the manual it says should be 40 mV.....(!). Is there something wrong here? I tried carefully adjusting them, but they only go to 30mV with the pots fully on, this doesn't seem right to me.
I compromised at 20 mV BIAS for both channels, and now the DC offset is 50 mV for L, and 5 mV for R, which is better, less than half what they were. I'm wondering, will I damage anything doing this, should I put them back to where they were?
The service manual is on site here.
Let me know if you want me to upload an english copy of the Owner's Manual, it has a better schematic in it all on one page, easier to read.
I've also included some pictures. They're not my actual unit, but mine is exactly the same, but less dusty.
Thanks for reading this. Many thanks in advance, and have a peaceful Palm Sunday! :taps2:
Bellarmine
A fenti autórádióval van gondom.
A hibajelenség:
tuner üzemmódban nem szól a rádió( még zaj sincs), nem lehet hangolni, nem reagál a két hangoló gombra(<< >>).
Próbáltam átállitani a menüben manual-ra, de akkor sem reagál a gombokra.
A többi gomb(FM,AM, programgombok, stb...) tökéletesen müködik.
Ha a menüből akarnám az automata hangolást elinditani, arra sem reagál.
A két hangológomb egyéb üzemben tökéletesen teszi a dolgát.
Nincs belepiszkálva, nem volt még megbontva sosem..
Mi lehet a gond???
Köszönöm.
Hi!
Ez egy nagyon profi cucc, nálam van a hozzá való erősítő is. Egymás nélkül nem használható, lévén ez a kütyü vezérli a végfokot is. Az egységen csak a készenléti LED világít, semmire nem reagál, nem ad vezérlést az erősítőnek. A tulaj szerint alaphelyzetben az időt mutatja. Nos ez ezt sem. Ahogy lenni szokott, az előlapi panelon szvsz elszállt a proci, 5V ok, -30V ok és az egyéb tápok is. A STBY gomb jelét ez fogadja és dolgozná fel. De néma csend, a proci az egyetlen aktív elem, néhány ellenállás, kondi és csók. Még quarc sincs. Valakinek egy elfekvő darab, vagy rajz mert olvashatatlan a tipus...:/ ?
Áram alá helyezéskor már a PROTECT felirattal kezd, semmilyen gombnyomásra nem reagál, cd-t beveszi-kiadja de nem forgatja meg és teljesen néma.
Végfok-ic, cd-egység eltávolítása után a helyzet ua., a regulátor ic-nél /IC901 LV5680/ vannak eltérések tápfeszekben, 6-8 lábon fele feszültség van a rajzhoz képest, a 14-15-ön pedig 0v a 4,9 ill. 13,5v helyett, az alaptápok mint a 3,3-5-8,5-9v-ok megvannak.
Nem tudom hogy bekötési hiba után lett-e ilyen vagy menet közben, van-e ötlete valakinek hogy mi lehet a gond, a regulátor ic cseréje sem túl egyszerű próbára mert 4-5ezer körül van S-nél és nem egyértelműen néz ki hibásnak, panel teljesen ép, gyanúsnak tűnő alkatrészt nem találtam, köszi.
