I greet you! I would need the scheme of this "vintage" amplifier that needs to be "restored". The problem is that in the prefinal and final floor I have many "fried" resistors well, their value cannot be identified.I replaced the defective transistors: 2SC1509, 2SA777,2SB690 and 2SD 796 (each 2 pcs.) and the electrolytic capacitors adjacent to them. I could not go further because of the carbonized resistors that I do not know their value (I can only guess that they are values small, in the order of ohms). The schematic diagram I downloaded, from the address received by the kindness of a colleague is not complete - it is a single page (missing Q29-Q30-Q31-Q3 and resistors R115-R116-R117-R118 which are completely carbonized, at other resistors I could see their value).Thanks in advance!
Finally, I found the missing part
If stuck in the repair and you ask questions, please do it as follows: - Details: Give the exact model number of your device and the chassis ID (if there is). - If possible, please attach pictures of the appliance. - Anamnesis: Write down the exact symptom. If hard to describe the symptom, it is difficult to verbally defined clearly, attach pictures or sound of the phenomenon! - Tell what was you have done so far: search contact error, which parts has examined or changed yet, etc... The incorrectly named topic suspended and will be deleted after 48 hours! Suspended state while others are not able to comment until you correct the address. Subsequent repair of the defective title (within 48 hours) by clicking on the "Edit" tab can be carried out.
Sziasztok!, nem rég olcsón meg vásároltam egy KENWOOD KA-5050R típusú erősítőt, a régi gazdája sajnos tönkre tette mind a két végfok-ját!. Ennek az erősítőnek a vég tranzisztorai 2SK1529, és 2SJ 200-as végtranzisztorokból áll, a kérdésem pedig az volna hogy ezeket a típusú tranzisztorokat milyen típusú tranzisztorokkal lehet még helyettesíteni?, ugyan is az összes végtranzisztor zárlatba ment!, és ezek a típusú tranzisztorok nagyon drágák, és egy kis seb vagyonba kerülne az erősítő újra élesztése, mivelhogy a 2SJ 200-as és a 2SK 1529-es ből 4-4 darab kell!. Ha valaki tudja mivel lehet még helyettesíteni ezeket a típusú tranzisztorokat azt kérem segítsen, és ha valakinek meg van a kapcsolási rajza az erősítőnek az is sokat segítene, mert még van négy darab ellenállás is ami oly annyira meg éget hogy a színkódot nem lehet le olvasni az ellenállásról, csak az első szint sikerült be azonosítanom ami a szürke szín. A négy ellenállás teljesen meg szakadt, le kapartam az ellenállásokról a védő réteget, hogy hátha le tudom mérni az ellenállást, a mérő műszer egyik mérő tuskéjét rá csatoltam az ellenállás egyik végére a másik mérő fejt pedig húztam felfele az ellenállás szén rétegén és ezeket az értékeket kaptam ahogy mentem felfelé 75ohm, 114ohm, 420ohm között mozogtak az értékek, én szerintem 820ohm-osak lehetnek az ellenállások, de nem vagyok benne biztos. Az ellenállások pozíció száma pedig a köv- R29, R30, R31, R32. Amúgy ezek az ellenállások a meghajtó tranzisztorok bázisait csatolja össze. A meghajtó tranzisztorokból van két darab 2SA 1535 aminek a C-ra, és a E-je össze csatlakozik a B-uk pedig csatlakozik ezeken az ellenállásokon keresztül a két másik 2SC 3944-es tranzisztor B-saira, és ezeknek a C-ra és az E-re is közös. Köszönöm!.
A fenti minihifi nem kapcsol be, áramingadozás után.
A tápban 3 dióda zárlatos volt két bizti kiment, ezeket megcsináltam, de még mindig nincs életjel.
Ha vkinek volna rajza azt megköszönném, ha elküldené.
UI. tudom rajzot nem itt keresünk, de a helyén már próbáltam eredménytelenül, megpróbálom itt is hátha több siker lesz a vége.
Nincs senkinek tippje?
Üdv Mindenkinek!
Fennt nevezett készülékhez keresek beépítő keretet, illetve azt a keretet, ami a levehető előlapot körbefogja. Fotó mellékelve Segítséget köszönve: FEJO
