Adott egy 29pt5407/21,ch:L01.1E színes tv.Első bekapcsoláskor sípol sorméret változik,csíkoz,majd pár perc után beáll és működik.ha kihül újból így kezdi.Amit néztem:tápfeszek stabilak,elkók mérve és cserélve,forrasztások átnézve nem kh.MELEGÍTÉSRE ÉS HŰTÉSRE nem reagál!A segítségeteket előre is köszönöm!
Hi everybody,
I have Philips 40PFL7007K/12 on repair. TV does not start up. I have checked the PSU and it seams to be OK. There seam to be problem on the main board.
What I have tried…
Well, there is +3V3-STANDBY coming from PSU to main board. This feeds up the main processor. This voltage has also been used to switch TV on. I have checked that switching signal from POWER ON button goes back to main board. But I did not check this whole path towards the processor as it is BGA package and it is covered by ceramic cooling plate.
And here comes what is not clear to me.
1. How to check if the main processor works? Does it work on the +3V3-STANDBY when TV is is standby mode?
2. Can I somehow check if the PSU is working? May be by activating some pin?
3. I have noticed by measuring (ohm-meter) some capacitors on the main board (in circles on the picture) that there is very low resistance on them (4.5ohms). In the scheme it is shown that these capacitors are on the 1V5 (1.5V) line. Is this OK? Basically it does not give much current as I = 1V5 / 4R5 = 333mAmps. What do you think? Certainly there are low voltage data parts (RAM. Processor …) connected and such resistivity might be correct….?....
What I have also find that this 1V5 is split into 1V5M0 and 1V5M1. See the picture. I have removed the coils and measured resistance. Then 1V5M0 shows about 15ohms and 1V5M1 shows about 6,5ohms.
The service manual is on this link:
http://elektrotanya.com/philips_ch.qfu1.1e_la.pdf/download.html
Thanks Martin
Kedves kollégák!
Ez a készülék bekapcsolás után 10-15 mp múlva kikapcsol. Amíg üzemel van kép és hang is. Akár tasztról akár távról lassan reagál a funkciókra.
A tápfeszek a tápon is és a main-on is min rendben megvannak. Amikor kikapcsol,akkor is minden táp megmarad,kivéve a PFC-t. Egyébként a PFC 412 V-on megy,nem tudom ez gond e. Mind két procit,hőprofilosan átmelegítettem.Minden kondi ESR értéke tökéletes. Hősokkos behatárolás nem segített. A proci rezonátorát cseréltem. Amikor kikapcsol,úgy jön vissza,hogy egyszerűen megjelenik a kép és a hang is.
Ha készenlétbe rakom furán veszi. Hibakódot nem villog. A proci mintha nagyon melegedne. De ha lehűtöm (fagyasztom) a kikapcsolási és a bekapcsolási idő semmit nem változik. Kicsit úgy tűnik,hogy szoftver hibás.De hogy lehet ezt egyáltalán újra szoftolni.
üdv.
Philips - LG LCD TV tápot keresek... (többet is) 42"-os tv-hez
