Hello
I have on my table this sony kdl32ex600 with backlight issue. It's a common failure of this psu but i do not find any part faulted on this board.
The schematic it is almost the same, with minor differences with GE3B found at page 56 on this service manual:
https://elektrotanya.com/sony_kdl-32ex600_kdl-40ex600_kdl46ex600_chassis_az1-k.pdf/download.html
Uploaded only the page 56 from this sm to easing the search.
The red led it's flashing 2 times, meaning psu faulty. Indeed the led backlight does not light.
With the PSU outside of the tv, just with one resistance of 180ohm between standby ( pin 1 3,3V on connector CN6150 ) i get this values
on in:
starting with pin 1
1 +3,3V ST-BY
2 +3,3V AC_OFF_DET
3 +3,3V POWER_ON (with resistance 180ohm between pin1 and pin 3)
4 +12,56V AUDIO_12V
5 0V AUDIO_12V_GND
6 0V REG_12V_GND
7 0V REG_12V_GND
8 +12,6V REG_12V
9 +12,6V REG_12V
10 +0,1V BL_ERR
11 +3,3V BL_ON
12 0V DIMMER
13 0V DIMMER_DC
14 0V T-CON_Vcc_12V
15 0V T-CON_ON
All measure done at secondary ground point C6800 GND as reference.
Meanwhile, the led connected to CN6800 will remain with no light at all. The CN6800 will deliver positive 91V.
The negative branch will deliver at CN6801 ( both pin1 & 2 ) just -1V.
In the training manual found always in here at
https://elektrotanya.com/sony_kdl-32ex600_40ex600_46ex600_chassis_az1k_training%20manual.pdf/download.html
at page 56 will say "SHORT" at pin 12 DIMMER for testing the PSU, always with pin 3 POWER_ON connected to 3,3V ST-BY - pin1.
If i'll put a 180ohm resistance between GND and pin 12 DIMMER, then the tension on CN6800 will rise to +179V and the negative from the CN6801 will rise to -5V, the backlight led will light very very weak.
All tension from CN6805 will remain the same, except the BL_ERR will rise from +0,1V to +1,1V.
With only power_on pin 3 shorted by 180ohm resistance to the pin 1, i get this weak oscillation at emiter of Q6816 + Q6817
[URL=https://picturepush.com/public/16067400][IMG]https://www1.picturepush.com/photo/a/16067400/640/diverse/Q6816Q6817.jpg[/IMG][/URL]
With pin 12 DIMMER shorted ( always by a 180ohm resistance ) at GND, the oscillation will change from 250khz 1,6vpp to almost 70khz at 0,81Vpp. as below:
[URL=https://picturepush.com/public/16067401][IMG]https://www1.picturepush.com/photo/a/16067401/640/diverse/20181117-175255.jpg[/IMG][/URL]
Already checked the capacitors C6828 / C6830 together with D6805 / D6806.
Also checked the L6800 ( trafo ) and i've get 5,5mH instead of 5mH, i think it's ok.
All fuse checked, ok.
Q6814 and Q6801 tested under mosfet tester, ok.
[url=https://picturepush.com/public/16067402][img=https://www1.picturepush.com/photo/a/16067402/220/16067402.jpg][/url]
IC6800 & IC6801 gave +9V and respectively +2,49V
Already checked various components all over the board, i am out of ideas.
Any idea or help would be apreciated.
Keresném a Sony KDL-32W655A NAND IC TC58NVG3S0FTAI0 flash tartalmát, ha esetleg valakinek meglenne, illetve tudna egy letöltési forrást azt megköszönném. Alaplap száma 1-888-154-11 (173416911).
Válaszokat köszönöm előre is.
Sziasztok! Egyetlen egyszerű kérdésem van egy RM836 tip. SONY távkapival kapcsolatban: hány kHz-es kavics kell bele? Évekkel ezelőtt én vettem ki,kellett egy másikba,elfelejtettem beleírni. Szeretném feléleszteni,nincs a közelben másik,nem tudom megnézni. Ha tudjátok akkor... Előre is köszönöm! Szép napot!
üdv mindenkinek!
Menü megjelenítési kérdésben szeretnék kérni segítséget!
Volt hibajelenség kérés:
A tv bekapcsol, távirányítóval irányítható, látszólag a funkciók hibátlanul működnek csak sajnos nincs osd megjelenítés!
A tv t-con hiba gyanúval került hozzám! később kiderült UB1 board hiba állt be!
Ma megjött usa-ból a ub1 board, ezt beszerelve a pc-ről van képem hangom minden funkció működik de nem látom mit hol álltok!
Egy másik bravia-val összhangban probáltam,igy láttam hogy minden elvileg a helyén van!
Mi lehet a probléma?
Megoldás:
Nos mindenkinek okulásként! Köszönhetően agresszív kollégának!
Mivel nem boldogultam vele és a kolléga is jelezte ez inkább szoftver hiba lehet, nem kívántam újabb USA rendelést indítani 35 ezerért, pláne azért hogy kaptam 15 ezerért komplett törött tv-t.(ez szerencs kérdése is volt)
A történet innen érdekes! Javaslom mindenkinek, erre érdemes odafigyelni!
A tv Maine-je 11 db csavarral volt lefogatva a mepeg4 modul 3 db csavarral. A hibás maint előttem más szaki vizsgálta kivette ellenőrizte, stb, legalább is gondolom. Abból mindössze 1 db csavar hiányzott a felfogatásnál! ez okozta a problémát számomra érthetetlen módon!
A jelenség egyszerű volt nem volt osd menü de minden más látszólag működött! Az oka:
Az mpeg4 kártya alsó oldali csavarja nem volt rögzítve (A többi igen!) de az az egy db az bizony nem!
A hozott tv-n volt kép, osd! (csak törött a kijelzője) mondom kipróbálom az újat átszereltem felfogattam hasonlóan jött a jelenség! Nincs osd az uj panellel!
Bepróbáltam a töröttbe a mainomat csavarral felfogatva, hátha másik panelban van a hiba!
bekapcsolom még egyszer, és most bejött az osd az én rossz mainommal és hibátlan!
Na gondoltam frankó! Most mi van? Kontakt hiba lehet!?
Mozgattam a panelt semmi, hőre fagyasztásra semmi! Akkor most mi van?
Nézem a paneleket és veszem észre hogy az egyik csavar hiányzik abból amit áttettem, lenyomom a panelt semmi osd.
Teszek bele csavart nmajd ujra bekapcsolom a tv-t és láss csodát van osd! Leveszem a csavart nincs osd!
Véleményem szerint nem fizikai áramköri letestelési gond volt mert összemérhetőek voltam műszerrel a testelések, viszont interferenciát és program működés zavart bizony okozott.
A törött tv-n levettem az mpeg4 kártyáról a csavart, újra bekapcsoltam s egyből eltünt az osd menüje is!
Majd alaposan visszatettem a lapot minden csavarral, és mindkettő hibátlanul működik!
Okulás: nem szabad megtévesszen bennünket a mainhoz rögzülő csavarok hiánytalan megléte!
Mivel nem én szereltem előtte és burkolat alatt volt a main, így az az egyetlen hiányzó csavar (burkolatban farraday kalitkában) is zavart okozott önmagának!
Köszönet agressiv kollégának a sok tanácsért! Ö vezetett a probléma megoldáshoz!
