a tárgyban jelzett tv bekapcsol megjelenik a kép majd kikapcsol és 4-et villog a stby led. Inverter megkapja a 18V-ot, és az inverter panelon sem találok hibás alkatrészt. Neten több helyen is inverterpanel cserét javasolnak. Valamelyikötöknek hátha megvan a megoldás, és lenne kedves segíteni.
köszi
Balázs
Mi lett volna, ha a készülék márkáját is beírod a címbe?? A pontos cím nem fáj! A cím nem neked szól, hanem a többieknek!
Hello
I have on my table this sony kdl32ex600 with backlight issue. It's a common failure of this psu but i do not find any part faulted on this board.
The schematic it is almost the same, with minor differences with GE3B found at page 56 on this service manual:
https://elektrotanya.com/sony_kdl-32ex600_kdl-40ex600_kdl46ex600_chassis_az1-k.pdf/download.html
Uploaded only the page 56 from this sm to easing the search.
The red led it's flashing 2 times, meaning psu faulty. Indeed the led backlight does not light.
With the PSU outside of the tv, just with one resistance of 180ohm between standby ( pin 1 3,3V on connector CN6150 ) i get this values
on in:
starting with pin 1
1 +3,3V ST-BY
2 +3,3V AC_OFF_DET
3 +3,3V POWER_ON (with resistance 180ohm between pin1 and pin 3)
4 +12,56V AUDIO_12V
5 0V AUDIO_12V_GND
6 0V REG_12V_GND
7 0V REG_12V_GND
8 +12,6V REG_12V
9 +12,6V REG_12V
10 +0,1V BL_ERR
11 +3,3V BL_ON
12 0V DIMMER
13 0V DIMMER_DC
14 0V T-CON_Vcc_12V
15 0V T-CON_ON
All measure done at secondary ground point C6800 GND as reference.
Meanwhile, the led connected to CN6800 will remain with no light at all. The CN6800 will deliver positive 91V.
The negative branch will deliver at CN6801 ( both pin1 & 2 ) just -1V.
In the training manual found always in here at
https://elektrotanya.com/sony_kdl-32ex600_40ex600_46ex600_chassis_az1k_training%20manual.pdf/download.html
at page 56 will say "SHORT" at pin 12 DIMMER for testing the PSU, always with pin 3 POWER_ON connected to 3,3V ST-BY - pin1.
If i'll put a 180ohm resistance between GND and pin 12 DIMMER, then the tension on CN6800 will rise to +179V and the negative from the CN6801 will rise to -5V, the backlight led will light very very weak.
All tension from CN6805 will remain the same, except the BL_ERR will rise from +0,1V to +1,1V.
With only power_on pin 3 shorted by 180ohm resistance to the pin 1, i get this weak oscillation at emiter of Q6816 + Q6817
[URL=https://picturepush.com/public/16067400][IMG]https://www1.picturepush.com/photo/a/16067400/640/diverse/Q6816Q6817.jpg[/IMG][/URL]
With pin 12 DIMMER shorted ( always by a 180ohm resistance ) at GND, the oscillation will change from 250khz 1,6vpp to almost 70khz at 0,81Vpp. as below:
[URL=https://picturepush.com/public/16067401][IMG]https://www1.picturepush.com/photo/a/16067401/640/diverse/20181117-175255.jpg[/IMG][/URL]
Already checked the capacitors C6828 / C6830 together with D6805 / D6806.
Also checked the L6800 ( trafo ) and i've get 5,5mH instead of 5mH, i think it's ok.
All fuse checked, ok.
Q6814 and Q6801 tested under mosfet tester, ok.
[url=https://picturepush.com/public/16067402][img=https://www1.picturepush.com/photo/a/16067402/220/16067402.jpg][/url]
IC6800 & IC6801 gave +9V and respectively +2,49V
Already checked various components all over the board, i am out of ideas.
Any idea or help would be apreciated.
Sziasztok! Találkoztatok már ennél a tv-nél olyan problémával,hogy készenlétiből 8-12 inditás után indul el a készülék?
Kedves Kollégák!
egy bravia tv kijelzőjével illetve annak problémájával vannak gondjaim.
A készülék hidehen nem kapcsol be 5 led felvillantással jelzi t-con hiba áll fenn!
Pár próbálkozás után beindul a tv és a háttérvilágítás is. előszór a háttér látszik egyenletes fekete háttérrel (kép értelemszerűen csak egy sötét háttérfényt ad, tehát nincs)
2-3 perc üzemelés után beugrik a képernyő teljes felületén zöld vízszint és függőleges csíkok sokasága de egész raszter felületen.
Pár napi átvizsgálást követöen a következőket tapasztaltam:
Tcon táp chipjeinek feszültségei jók, alapból zavarmentesek (szkóp) minden tápfeszültség rendben a gyári értékekekn megtalálható! A BGA chipek langyosak, a burkolat mellett fél óra multán kellemesen melegek! Minden chip megkapja a szükséges tápot!
Az eddigi feszültség ingadozást az okozza (induláskor), alapos megvizsgálást követöen, hogy a main és t-con közötti köztes panelen UB1-en van egy tápáteresztő fet ami ki és bekapcsol. Azaz valamilyen hibát észlel, és letiltja a t.con tápellátását! (áramfelvétele a t-con és kijelzőnek a sema szerint is rendben, bár kép nincs, viszont akkor sem vesz fel több áramot, ha a kép kizőldül! Cof chipek egytől egyig rendben vannak, langyosak.
a t-conhoz érkező 100 herzes elosztó lap biztijei és tápfeszültségei most alaposabb árvizsgálást képeznek, mivel sema szerint van vagy 12 helyen ellenállás bizti! Bár tápfeszültséget előállító chipek látszólag rendben vannak.
tovább jutottam a hiba behatárolásán!
TV távjával a bemeneti csatornák változtathatóak! amikor a pc bemenetre lépek a pc-ből érkező hang bejön. A zöld képes háttér enyhe szürke egyenletes szinre vált és a zöldesség teljesen eltünik.(világos egyenletes szürke raszter) egyíébként mikor sávbemenetet váltok el eltünik a zöld majd más csik állapotban visszajön üres csatorna esetén!
HA jellel ellátott csatornára teszem a zöldesség minden esetben eltünik!
3 féle dologra gondolok és ebből mostanra meglett a probléma forrása!
1. T-con chip OK! vagy LVDS BGA chip main-on OK! vagy UV1 chip KONTAKTHIBA BGA forrasztásban!!! (forrósodás, zárlatra utaló nyom egyértelmüen nincsen) A hűtőt leszereltem és enyhe nyomásra a kép hibátlanul bejön!
Tehát a sejtelmem beigazolódott, az UB 1 panel hibás (ez a panel csinál 2 csatornás LVDS jelből 4 csatornás LVDS jelet a 100 herzes kijelzőnek.És ennek BGA tokozásu chipje vált le a forrasztásról!
Mit javasoltok? rebuild vagy ujra golyózás? Valaki tud ilyet vállalni?
köszönettel Attila
