I have a Yamaha CDX-590 CD player and it skips on some CDs - original CDs, these CDs play without problems on my other CD players.
I have changed the laser unit (KSS-210A) but this didn't solve the problem.
When I turn the player upside down, it plays the problematic CDs without a problem.
That's why I think the laser needs adjustment.
I have only a service manual for the CDX-493/593 but they should be very similar to the CDX-590.
It seems that the adjustments are done via "test mode" of the CDX-590, unfortunately there is not much information, how to exactly, in the service manual.
Here is a picture of the PCB.
http://www.volny.cz/hwtest/PCB.JPG
Here are the "test mode" sections of the service manual.
http://www.volny.cz/hwtest/TM1.GIF
http://www.volny.cz/hwtest/TM2.GIF
In "test mode" I have tried Auto adjustment mode 1, 2, 3, but I don't know if it should work fully automatic without any intervention or when the mode is fineshed and I can proceed to the next one.
So I activated mode 1, waited a while, activated mode 2, waited a while, activated mode 3, then exited test mode.
It didn't help.
Mode 1 - only a short blink of two horizontal dashes on the display and thats it
Mode 2 - started "play" without sound from a strange time 99:00 (the test CD is not so long), after a while it skips to another time, "plays" a while, then skips back and "plays" and so on, I left it about an hour and it was still going on
Mode 3 - seems to be very short as mode 1
I think I'm missing something ...
Maybe someone did this or even serviced Yamahas in an official service and can provide information how to adjust the laser?
Or maybe the problem is not the laser?
A címben említett AV Receivert hogyan lehet úgy mondván "RESET"-elni?
A neten találtam több "újabb" szériákhoz leírást + videókat is.
Hogyan kell. Az ok, hogy mindegyiknél bekapcs előtt nyomva kell tartani egy bizonyos gombot.
Azt utána a POWER gomb.......
Konkrétan ehhez a típushoz nem nagyon találtam!
Próbálkoztam több gomb párosítással.
De láttam olyat is, hogy bekapcs előtt 2 gombot nyomtak meg és utána a power gomb.
A szervizkönyvébe sok minden le van írva, hogy mit hogyan kell tesztelni, mint SZERVIZ felület.....
De mint FactoryReset olyat nem nagyon találtam, hogy visszaállítsam gyári beállításra.
Vagy, én voltam balfa**, azt sikerült átsiklanom felette.
A tünet:
Összességében bármely bemenetről hajtva "furcsán" szól.
Semmi szép hangzás az adott készülék tudásához viszonyítva.
Igaz aki hozta nekem, hogy nézzek rá.....
Ő annyit mondott, hogy nyomkodta össze vissza, olyan beállításokat is talált amiről fogalma nincs.....
Eddig még komolyabban nem másztam bele.
Csak 1-2 alap mérés.
Primer oldalról 140mA a felvétel nyugalmi helyzetben kb 30-33W. Ami szerintem jó.
Hangszóró kimeneteken terhelés nélkül 48-60mV. Ami szerintem nem lehet probléma. (STK404-120 és STK402-120Y a vég)
Csak még mielőtt belemerülnék....
Megpróbálnám elsőnek a gyári beállításokat.
Na ezt kellene visszahozni valahogy.
Köszönöm.
Kedves Mindenki!
Segítséget kérnék a fent nevezett erősítő javításához. Szokásos segédtáp hiba javítása után az történik, hogy bekapcsolás után 1 másodperccel lekapcsol, táp hibára panaszkodik, melyben úgy néz ki igaza is van...
PS PRT 022 D a hibakód, de a szerviz menüben 021-022 között ingázik.
A nagy trafón 49.8V helyett 57V-ot a 77.1V helyett 82.8V-ot mérek a műszerrel.
Van valami tippetek? Gondolom továbbra is a segédtápon kellene keresgélnem...
Előre is köszönök minden hozzászólást!
Gábor
Folyt.: segédtáp ok. Túlterhelés lesz, nézem tovább a többi panelt.
A címben szereplő Yamaha AX 500-as erősítő rajzán nem láthatóak a feszültségadatok.Ha valaki ki tudná egészteni a végfok és a védelem tranzisztorok lábain mérendő feszültségek értékét,az nagy segítség lenne a javításnál.Ugyanis a tápfeszek,és az összes alkatrész jónak tűnik,de az erősítő mégsem indul el.
A válaszokat előre köszönöm!
