I have a Yamaha CDX-590 CD player and it skips on some CDs - original CDs, these CDs play without problems on my other CD players.
I have changed the laser unit (KSS-210A) but this didn't solve the problem.
When I turn the player upside down, it plays the problematic CDs without a problem.
That's why I think the laser needs adjustment.
I have only a service manual for the CDX-493/593 but they should be very similar to the CDX-590.
It seems that the adjustments are done via "test mode" of the CDX-590, unfortunately there is not much information, how to exactly, in the service manual.
Here is a picture of the PCB.
http://www.volny.cz/hwtest/PCB.JPG
Here are the "test mode" sections of the service manual.
http://www.volny.cz/hwtest/TM1.GIF
http://www.volny.cz/hwtest/TM2.GIF
In "test mode" I have tried Auto adjustment mode 1, 2, 3, but I don't know if it should work fully automatic without any intervention or when the mode is fineshed and I can proceed to the next one.
So I activated mode 1, waited a while, activated mode 2, waited a while, activated mode 3, then exited test mode.
It didn't help.
Mode 1 - only a short blink of two horizontal dashes on the display and thats it
Mode 2 - started "play" without sound from a strange time 99:00 (the test CD is not so long), after a while it skips to another time, "plays" a while, then skips back and "plays" and so on, I left it about an hour and it was still going on
Mode 3 - seems to be very short as mode 1
I think I'm missing something ...
Maybe someone did this or even serviced Yamahas in an official service and can provide information how to adjust the laser?
Or maybe the problem is not the laser?
Jó reggelt mindenkinek!
Van ez az izé. Stby tápban zárlatos fet. Csere után van 5 volt a kezelőn. És ennyi.
Pont marhára nem izgatna de egy haverkollégáé. Ha valaki szeretne vele molyolni, viheti.
Tisztelt Mesterek!
A címben szereplő erősítő bekapcsol, és 3 mp múlva ki. (Doksi itt a tanyán van hozzá) A védelmeket service menüből kiiktatva DC PRT 87% üzenettel indul. Eszerint a kimeneti DC védelem aktív, a kimenetek és a GND között 5.5V-ot mérek. Minden kimeneten! A menüben a 10. menüpont első almenüjében DC: 87% PS: 16%. SM szerint DC 7-100 között, PS 27-47 között. A negyedik almenüben IMP 8 PL 255% Itt ír valami treshold feszültségről, de nem értem, pontosan mi lehet.
A uC (IC 472) PRI lábán 0V van 1.2 helyett, a PRD lábon pedig 3,96 szintén 1.2 helyett.
Mellékelem az STK végfokokon mért feszültségeket. A +12V-os stab elég rendesen melegszik és a rajzon szereplő 12V helyett csak 11.88V. Lehet ennek a túlterhelése a probléma fő oka? De akkor mi vitte el a végfokok feszültségeit ilyen drasztikusan?
A méregetések közben sikerült az IC303 5 és 6 lábát rövidre zárnom, minek következtében már nem tudtam kiiktatni a védelmet sw-ből. Ezt az IC-t kivettem és most újra tudok mérni. A feszültség viszonyok nem változtak. Előtte ugyan azokat mértem ezen az IC-n, mint IC302-n.
Kérem erősítő javításban nálam jártasabb kollégák segítségét!
Szerk: Nem volt minden összeföldelve, így a mérési adatok tévesek voltak. Így már az IC302-n jók a feszültségek. A Center végfokon viszont van némi eltérés. Ezt azért mellékelem. A PRI lábon 0.01V, a PRD lábon 1.38V a mért érték szemben az 1.2V-tal. A diagnosztika menüben kiírt értékek és a tünetek nem változtak.
Bocs a hosszáért!
u.i.: Ha kiveszem az összes végfokot és R358-R361, R350 (kimeneti ellenállások) "közepére" 0V-ot teszek, a védelemnek elvileg ki kell kapcsolnia nem? Bár elég valószínűtlen, hogy mindhárom STK egyszerre ugyan úgy romoljon el. Lehet, hogy a meghajtó IC romlott el, húzza le a tápot és ad DC-t a bemenetre? Bár a kondis csatolás miatt ez meg nem valószínű...
Megoldás: A uC (IC472) 90. lábához vezető fólia hibás. (Valszeg szakadt.) Ezért a DC védelem letiltott. A proc lábát felemeltem és egy darab huzallal D480 katódjára kötöttem.
sziasztok!
yamaha r-700 rádioserösítő kapcsolási rajzára lenne szükségem vagy legalább a hangszínszabályzó ic számára,hmm valaki kiszedte! köszi
