PANASONIC TX-P50G10
18.4 MB
    PANASONIC TXP-50G-10 TXP50G10 TXP 50 10 TX P50G10 TX-P50G10
Panasonic Plasma TH-85PF12E Error code " 4 Blinks "
 This elderly monster arrived with the error “ 4 blinks “ which the manual suggests is a power board fault
There are TWO power boards and a standby power board inside
On removing rear cover there were two swollen 220uf caps on the standby board, sadly replacing them the 4 blinks remained
Swapping the two power boards over[ as they look identical , gives a “ 2 Blink “ error , the limited info in the manual suggesting that the fault is on the lower board [ main 2 ]
Both boards have a PFC voltage of around 380 volts at switch on before the relays click out
I have done cold checks on both boards and there are no obvious differences
As the manual has only a block diagram of the power supply  it’s difficult to be sure of values / voltages
Has anybody seen or worked one of these or similar beasts and managed to diagnose the problem
Thanks for looking
Regards  Ken
Panasonic TX29 PS12P TV chassis CP830 FP
Üdv! Mesterek, a fentilapon sorkicsere után nincs E.W vezérlés. Eredeti sorki. 13022002C (Ap8)ami az alján kilyukadt, cseredarab TRRO 0777. Kérdésem lehet nem csere szabatos a sorki? Ezenfelül ha valaki adna jó ötletet azt megköszönném.Menni megy a gép, csak a torzítással.
panasonic lcd
Udv es boldog Uj evet mindenkinek!Volna egy Panasonic TX32LE7P/SA,GLP21MA sasszi,amellik egy halozati lorugas eredmenyekent bedoglott.MR4040 totalkaros,puffer kondi kinyilt mint a tubarozsa.Ezeken kivul minden OK(?).Csere utan uresben tap indul de terhelessel ledoglik.Ha egy ideig pihen a draga inditaskor pillog zolden a st.by led majd megjelenik a kep de villog,majd st.by,azutan ujra pillog zolden a st.by majd megjelenik a kep villogva.Ha ezt tobszor eljatszom a tap ledoglik,se te piros se te zold st.by led, csak halk tucsokzene a tap felol.Na ezt adja ossze valaki es huzon ki a slamasztikabol!!Elore is koszonok minden hozzaszolast!!
Panasonic TX-49DX600E Smart tv hirtelen elsötétült, se kép se hang
Szevasztok.
Nejem tv nézés közben szembesült a fenti hibával.A készenléti led folyamatosan zöldet világit. A távirányitó gombjaira a led vibrálása a válasz.
Sem a távirányitóval, sem a tv főkapcsolójával nem kapcsol ki. Ha a hálózati dugaszt kihuzom és ujra bedugom ismét a zöld led világit. a piros
kikapcsolást jelzó fény sosem jelenik meg.Mi lehet a gond.Meguszható e enyhébb javitási költséggel?
