Hi everybody,
I have Philips 40PFL7007K/12 on repair. TV does not start up. I have checked the PSU and it seams to be OK. There seam to be problem on the main board.
What I have tried…
Well, there is +3V3-STANDBY coming from PSU to main board. This feeds up the main processor. This voltage has also been used to switch TV on. I have checked that switching signal from POWER ON button goes back to main board. But I did not check this whole path towards the processor as it is BGA package and it is covered by ceramic cooling plate.
And here comes what is not clear to me.
1. How to check if the main processor works? Does it work on the +3V3-STANDBY when TV is is standby mode?
2. Can I somehow check if the PSU is working? May be by activating some pin?
3. I have noticed by measuring (ohm-meter) some capacitors on the main board (in circles on the picture) that there is very low resistance on them (4.5ohms). In the scheme it is shown that these capacitors are on the 1V5 (1.5V) line. Is this OK? Basically it does not give much current as I = 1V5 / 4R5 = 333mAmps. What do you think? Certainly there are low voltage data parts (RAM. Processor …) connected and such resistivity might be correct….?....
What I have also find that this 1V5 is split into 1V5M0 and 1V5M1. See the picture. I have removed the coils and measured resistance. Then 1V5M0 shows about 15ohms and 1V5M1 shows about 6,5ohms.
The service manual is on this link:
http://elektrotanya.com/philips_ch.qfu1.1e_la.pdf/download.html
Thanks Martin
PHILIPS GR2.4 függőleges eltérítő fokozatában, zárlatos lett a 7503 poz. BD536 tranzisztor, és a 6505 poz. LL4148 dióda.
Segítséget kérnék, mert még a helyettesítője (BD 538)sem kapható.
Van e valami amivel helyettesíteni lehet?
Károly
Jó napot a fent nevezet táphoz kérnék egy kis segítséget még pedig a panelon lévő 2db dual dióda katód lábán aminek a tápon lévő száma D9102 15,6v mérek itt 18v kéne lenni-e,a másik bual dióda D9116 12v helyet 10,1 v -van, apanelon cseréltem az összes elkot,Q9101,R9110,R9111,R9109,R9113,U9101,R9114.A panelon lévő U9102 optó csatoló 1 lább10,1v,2 láb 9,1v 3 -4 láb itt a feszültség ingadozik 22,3-26,3v között. Az volna a kérdésem ,hogy mi okozza azt, hogy 12v-18v a tápegységen nem a megfelelő érték.
Cseréltem az U9103 TL431 csere után még mindig 11V-16V van jelen a dual dióda katód lábain,majd a tápon cseréltem az U9102 optó csatoló a csere után a dual dióda katód lábain mérhető volt a 12v és a 18 v,
Igy utólag meg köszönöm mindenkinek a segítőkész hozzá szólását,remélem ,hogy ha valaki javítása során találkozik egy ilyen hibával remélem segítségére lesz ez a bejedzés,
Tisztelt kolegák!
Ismét hozzátok fordulok tanácsért. A fenti típusú készülék teljesen működésképtelenül került hozzám. A táp javítása után a kapcsolási rajzon szereplő feszültségek a stabok kimenetein megvannak. A készülék bekepcsolható, de csak a három alapszínt váltogatja a kijelzőn.Nem tudom merre induljak tovább.Kérem a segítségeteket.
