ACER AL1912
MONITOR - SERVICE MANUAL
2.8 MB
MONITOR
Looking for similar acer manual?
ACER AL1912 service manual (1st page)
Preview of ACER AL1912 [1st page]
ACER AL1912 service manual (2nd page)
Preview of ACER AL1912 [2nd page]
    ACER AL-1912 AL1912 AL 1912
ACER GD245HQ Monitor nem üzemszerűen működik. Megoldva!!!
Kedves kollégák!
Valószínűleg Flash vagy eprom hibás a kicsike. A kijelző teszt üzem módban van a végtelenségig(szinek váltogatása). Ehhez keresnék tartalmat.
Elvileg a szokásos orosz aranybánya oldalon van hozzá.
https://remont-aud.net/dump/mnt/acer_gd245hq_shassi_main_board_48_7d701_021/12-1-0-43688
Sajnos én ide nem tudok bejelentkezni(teszt kitöltést nem tudom értelem szerűen lefordítani). Ha meg tenné valaki,hogy letölti.Nagy lenne az öröm!!!
üdv.
Acer V223HQ - ILPI-075 Rev.A power supply turns off
Hi, I'm sorry for writing in English, but I don't understand any single word in Hungarian and I couldn't find an English subforum there. I have changed the LVDS controller and now it's working perfectly, but I need help with the backlight. The CCFL lamps in the screen are OK. I connected the screen to another inverter (from BenQ T705, made on TL1451 which also has "protect" function) and the backlight worked perfectly. Again, I connected other screen to the malfunctioning ILPI-075 inverter and the screen also goes blank. I changed all THT electrolytic capacitors on the board, but not much has changed. Before, the backlight was turning off almost immediately, now it glows for 1-2 seconds and then turns off. The HV side of inverter transformers is about 470 ohm, they look OK. I measured random capacitor in the +16V line, which is supplying the high voltage inverters. We can see how the voltage went down while the backlight was powered on. Also, the ON/OFF signal on ICL837's pin 8 is always present after powering up the power supply, even after the backlight turns off. I don't have any idea what to check now..
ACER S240HL scaler:4H.17601.A00 LED Monitor nem kapcsol be csak készenlét van.
Üdv.Mindenkinek! Fent nevezett monitort nem lehetett kikapcsolni(tökéletesen működött). Mérés után kiderült,hogy a tasztja hibátlan. Mivel semmiféle memóriatartalomhoz nem jutottam hozzá hirtelen,csináltam egy eeprom resetet(gondoltam hátha megjavul) balszerencsére,mert azóta csak készenlét van.Időközben egy jó ismerős koléga a remontaudio oldalról letöltött nekem 2 tartalmat de egyikük sem tartalmaz eeprom tartalmat. Ehhez kellene segítség. üdv.
Acer b245h Monitorhoz flash ic keresése
Szép napot kollegák! Van egy monitor nállam úgygondolom flash ic hibás.Nem ad életjelet,előlapi led nem világit.Ahova be volt dugva hosszabbitóba abba teát öntöttek és azóta nem kapcsol be.Tápokat megnéztem pwm icét cseréltem a tápban de semmi változás. A lényeg hogy van benne egy pmc flash ic tipusa:pm25lv020 amit nem birtam se kiolvasni,se újraírni.(usb programozóm van ch341a)Venni akartam ilyen flasht,mert tartalmam van hozzá,de nem kaptam ilyen flash icét,ezért szeretném megkérdezni hogy mivel lehetne helyettesiteni?Segitségeteket előre is köszönöm. ic adatlapja:http://dalincom.ru/datasheet/PM25LV020.pdf Krisztián
