Hi,
My column Marshal Acton 2 , is dead . Power suplyy is it ok ... 18 V , but not light and not power on.
I need some help, and i try to find schematic !
Do tou can help-me ?
Best regards
Hi all,
I need a little help to repair my Akai PM-750 amplifier (part of system mx-750).
The voltage selector has broken and I don't know wich wires shoud I put together to get it work under 240V.
Service manual is no help, they just give spares parts...
Huge thanks to who could help me :-)
Want to share:
Have downloaded the schematics from this forum to help repair the amplifier of a friend.
Turned out that Sony decided to route the earth through the chassis, even the earth between the various supplies.
When one takes the main board out of the chassis and switches the amp on, there are up to 20 volts difference between the eart (and hence reference) of the pre-amps and the main amps.
Luckily the amp goes into protection but from a design point of view it is not nice to rely on screws and aluminum face plates to conduct up to 0.2 amps of current from one supply to another.
What I did is solder wires to every eart point and connected them on the main board to make it stand alone and not rely on conducting current through the chassis anymore.
Bad design, simple repair but took some digging in the schematics to find out what exactly was going on!
Van egy ilyen Samsung HT-WS1 Crystal Surround Air Track Soundbar-om amihez van gyárilag egy Wireless Subwoofer PS-WWS1 is ami vezeték nélkül kapcsolódik a Soundbar-hoz.
Az a problémám, hogy
amit találtam manual-t hozzá, abban pont erről nem esik semmilyen említés. A problémám az, hogy a Subwoofer, egyik napról a másikra egyzser csak elnémúlt.
Ez annyit takar, hogy nem néma, hanem olyan halkan szól, hogy csak kézzel érezhető hogy van hang, azaz mozog a hangszóró, közelebb hajolva hallani is, de élvezhetetlenül halk.
Amit találtam a PCM azonosítója:
Samsung AH94-02239B PC Board-Amp, Ht-Ws1
Képek (netről) a PCB_ről:
Wifi panel:
Ezen kívül semmit nem találtam róla.
Esetleg valaki nem javított ilyet vagy nem tudjam merre induljak el, mindihol neten annyit írtak, hogy szervízbe vigyem be, vagy cseréljem az erősítő PCB-t egyben:(, ami nem egy gazdaságos megoldás..
Köszönöm szépen előre is.
