A címbeli tévén (THP1008A sasszi) el van jobbra csúszva a kép az alábbi linken látható módon.
http://kepfeltoltes.hu/141216/DSC_0763_www.kepfeltoltes.hu_.jpg
Ha oldalról meg van ütve a tv akkor visszaugrik a rendes kép, de hamarosan újra elugrik. Az AKAI feliratnak középen kellene lenni. A csíkok a fényképező miatt vannak rajta. Mitől lehet ez képcső?
Köszi.
Hello to everyone, I hope someone can help me in English :D
i have a problem with this LCD TV Akai AZ 4280FHDT4 LCD 42" .
It's power supply was fault, and I got it working, but now i have another problem, there is no picture. Actually the screen is fade white-blueish, no picture no OSD, but SOUND is working fine...
I can't find service manual for this TV anywhere... And that is even more difficult because I cant see what is the main processor and the main IC on T-Con Board, because there is a glued cooler over them.
The main board is:20-MT5362--13-OX
The card that controls the LCD screen: SZTHTFTV1607
Power supply: MLT198TL
I suspect the T-CON board, because i get 12V from main board going too it, but there is no supply for main processor on TCON (probably MST6xxx IC), there should be 3.3v to supply it, but there is not... there is i thin a DC to DC convertor that should convert 12 to 3,3 but i cant read any marks from it, so i don\t know what it does exactly.
Here is what the board is, i think, it has its cooler taken off...
http://download.szlva.com/QQ/ep/EP00041200118.pdf
Here are the pictures of the tv set adn individual modules
http://i50.tinypic.com/ifuc6g.jpg
Behind
http://i46.tinypic.com/2csf5mf.jpg
Main Board (20-MT5362--13-OX)
http://i50.tinypic.com/259wsok.jpg
Power supply (MLT198TL)
http://i46.tinypic.com/f2kkkx.jpg
Others
PNEL - T805A
http://i48.tinypic.com/rb9xer.jpg
AV/HDMI/USB modul
http://i45.tinypic.com/eddg1.jpg
SZTHTFTV1607
http://i50.tinypic.com/2m65n2s.jpg
Remote
http://i45.tinypic.com/2e4dlcl.jpg
If anyone knows where can the service manual can be found it would be nice...
I see that many LCD tv's have similar problems, and that the LCD driver is mostly the reason...
Is there any similar manufacturer, that could help too...
Thank you in advance
Üdv.Mindenkinek!
Érdekes hibát produkál a szutyok. HDMI-n full ok a kép is hang is.
Viszont euroscart ról már fura szinkronhiba jelentkezik.
Alapból a menüje televan mindenféle krisz krasz-al.(emiatt nem is lehet programozni)
Mindenképpen jó lenne egy epromtartalom,vagy legalább az alaplapot beazonosítani.egyébként úgy tűnik,hogy a mostanában bekerült 106" HIUNDAY néven futott gagyiknak hasónló a belseje. A régi link.
http://elektrotanya.com/?q=hu/content/megegyszer-akai-ax-3230whd-lcd-tv-menuhibas
üdv.
Erre nem is gondoltam!
Agressív tippjére(köszönet érte)
A procit átforrasztva a hiba megszünt.
Viszont most már távszabályzó kellene hozzá(akár tanítható is)SOS
Sziastok
Faluról hozták ezt a tv t azt mondták 10-15 percenként kikapcsol aztán magától visszakapcsol.Régebben kb2 óra után kapcsolt ki elhozták akkor is ,nálam eggy fel nap után sem kapcsolt ki.Most is járattam 2 órát nem kapcsol ki.Mit cseréljek benne? A 300v-on cseréltem kondit és a szekunder részben is a 160-voltosokat még a multkor.
