AKAI CT20WKD 24C04 72A2202
TV - EPROM
Type: (BIN)
512.0byte
EPROM
Looking for similar akai manual?
    AKAI CT-20WKD CT20WKD 24C04 72A2202 CT 20 WKD 24 04 72 2202
AKAI AKTV4329M SMART software
I greet you with respect, sorry for the trouble, I would be interested if you somehow have a software available on usb for an AKAI AKTV4329M SMART TV that starts with the logo, then freezes and stops. Thank you very much!
Akai AZ-4280FHDT4 LCD TV 42", Has sound but has no picture
Hello to everyone, I hope someone can help me in English :D i have a problem with this LCD TV Akai AZ 4280FHDT4 LCD 42" . It's power supply was fault, and I got it working, but now i have another problem, there is no picture. Actually the screen is fade white-blueish, no picture no OSD, but SOUND is working fine... I can't find service manual for this TV anywhere... And that is even more difficult because I cant see what is the main processor and the main IC on T-Con Board, because there is a glued cooler over them. The main board is:20-MT5362--13-OX The card that controls the LCD screen: SZTHTFTV1607 Power supply: MLT198TL I suspect the T-CON board, because i get 12V from main board going too it, but there is no supply for main processor on TCON (probably MST6xxx IC), there should be 3.3v to supply it, but there is not... there is i thin a DC to DC convertor that should convert 12 to 3,3 but i cant read any marks from it, so i don\t know what it does exactly. Here is what the board is, i think, it has its cooler taken off... http://download.szlva.com/QQ/ep/EP00041200118.pdf Here are the pictures of the tv set adn individual modules TV http://i50.tinypic.com/ifuc6g.jpg Behind http://i46.tinypic.com/2csf5mf.jpg Main Board (20-MT5362--13-OX) http://i50.tinypic.com/259wsok.jpg Power supply (MLT198TL) http://i46.tinypic.com/f2kkkx.jpg Others PNEL - T805A http://i48.tinypic.com/rb9xer.jpg AV/HDMI/USB modul http://i45.tinypic.com/eddg1.jpg SZTHTFTV1607 http://i50.tinypic.com/2m65n2s.jpg Remote http://i45.tinypic.com/2e4dlcl.jpg If anyone knows where can the service manual can be found it would be nice... I see that many LCD tv's have similar problems, and that the LCD driver is mostly the reason... Is there any similar manufacturer, that could help too... Thank you in advance
AKAI CT-2107DT sorkimenő trnszformátor csere után,kivágta a sorvégtranzisztort.Megoldva.
Szevasztok van ez a tv javitáson,kifüstölt a sorkimenő trafója,csere után,a tv elindult,de kép az nem voltfütés ment,aztán észrevettem egy elenállást,ami az ABL ről jön hogy elvan égve,valahogy a rajz sem pászol ehez a készülékhez amit letöltöttem,mert nekem R424 van a panelon,rajz szerint meg végkép a sorkimenő bázisán van,na kicseréltem ,bekapcsolás után egy nagy fütty,és elszált a sorkimenő,na most jólenne valahova elindulni,lehet hogy vitte a procit is? A B+ 125 volt,nemtudom nem e sok egy 51 es csőhöz,a rajzon semmilyen feszültség érték nincs feltüntetve. Ha tudnátok hozzávaló rajzot megköszönném.
AKAI ct-v29ntf-pf-e10 (Rolsen 72FDS107 ch.LPCB0018) anomáliák
Üdvözletem! Egy akai ct-v29ntf-pf-e10 (Rolsen 72FDS107 ch.LPCB0018) típusú tv készülékkel kapcsolatban kérnék segítséget. A tulaj csak annyit mondott; rossz a kép. Bekacsoláskor egy visszafutásos "zizgő" képet láttam. Gondoltam kondi. Megdöbbenve tapasztaltam, hogy a táp és sorkimenő szekunder oldalán az összes kondinak annyi. Egy marék kondi csere után bekapcs. Kép felső része visszafordulva. Megint két kondi csere a képeltérítő környezetében. Bekapcsolás után kép jó. 10-15 perc működés után a kép felső része megint kezdett elbutulni. Ekkor vettem észre, hogy a tévében képeltérítő, stab ic-k, sor és táp tranzisztorok hűtői forróak. A képeltérítő körében levő kondik is melegek. C406 (új) kondi teljesen kapacitás vesztett lett. VD470-471-401 diódákat cseréltem. Nincs tapasztalatom ezzel a tv-vel és hibával. A segítséget előre is köszönöm! Péter Most még kijavítottam. Ez nem lesz mindig így..... Kalex
