ARLINE 62-9025A GRETSCH G6152
73.6 KB
Looking for similar arline manual?
ARLINE 62-9025A GRETSCH G6152 service manual (1st page)
Preview of ARLINE 62-9025A GRETSCH G6152 [1st page]
    ARLINE GRETSCH G-6152 629025A G6152 629025 6152 62 9025A 62-9025A
ION Archive LP Turntable
This is a compact design to I guess transfer the vinyl into MP3 format.
Complaint was when the arm was moved the tt dont spin, confirmed that as
theres a leaf switch to sense arm movement,
and its fed to a main pcb with all the IC's that I guess handle all the
stuff. The switch is ok, and I remember seeing 14V or so on the motor pins
frm the PCB, so I figured perhaps theres anough current to spin the motor and
focused on testing the motor.
Manufacturer does not supply the mainboard that feeds the motor but
the motor can be taken apart and after I opened it and
disconnected the small pcb fron the motor terminals and apply power
directly, it spins w 12v. theres a small electrolytic cap on the pcb 25V / 22uF and an
AN6652 4 pin T0-220 type case IC that I guess is some kind of speed control
circuitry.
The drive Motor is an EG-530-SD-3F, main board is stamped K-13007.
Gonna check the cap, but after searching this IC and its
applications with the motor, I see its popular and some drawings show how its used to regulate the 78,33
and 45 rpm speeds.
This drawing looks pretty much what I see in there:
https://tectronelectronics.eu/images/thumbnails/465/465/detailed/31/eg530.jpg
I have replaced the IC and the cap, but the motor still does not turn. The main pcb
is proprietary and cant be purchased, and I think it is giving the op-amp IC a reference signal.
Is there a way to bypass that signal or fool the IC to believing its on to test it out?
Photo showing the motor pcb :
http://www.mediafire.com/view/s79blgku1503mtg/HPIM0643.JPG/file
Photo of motor under test:
http://www.mediafire.com/view/thhgvcwac8al7gu/HPIM0635.jpg/file
Seat Alana autórádió kód
Szép napot! A fenti autórádióhoz szeretnék a hozzáértőktől egy kódot kérni. SEZ2Z9F1011919 Valami Grundig gyártmány. Nagyon szépen köszönöm a hozzászólásokat előre is!
Magnat classic 180 Autóerősítő kapcsolási rajzát keresi
magnat classic 180 autóserősítő kapcsolási rajzát keresem mert hozárk jívítani , de már belenyúltak előtte és nem tom mihez vagy mit cseréltek..
Onkyo TX-SR507 végfok hiba. MEGOLDVA!
Adott acímben szereplő házimozi erősítő amiben tönkre ment egy pár alkatrész.Ezek közül a 2sb1369-et nem kapok a hq elektronikánál (onnan szoktam rendelni). Abban kérem a helpet hogy ezt honnan tudnám beszerezni (nem horror áron), vagy ha van helyettesítője akkor annak típusát megköszönném. Találtam egy 2sb1370-et. Az adatok szerint ez is jó lehet...vagy nem?
Kicseréltem a meghatókat az MJE340/MJE350 párosra, a véget 2SC5200/2SA1943 párosra és még 2db 10A-es bizti aztán indult is. Mindenkinek nagyon köszönöm a segítséget!
Szép napot!
