Sziasztok:van ez a fent nevezett gép amelynek a fűtését kettő darab klixon szabályozza(a fűtőszálra vannak fogatva).Ezeknek az értéke 210 és 260c,amelyek szinte szét égtek.Hol lehetne ezeket olcsón beszerezni,vagy valami helyettesítőket(olcsót) berakni(gondolok itt egy kicsit más,kisebb hőértékű klixonokra) .Segítségeteket előre is köszönöm.ÜDV:LACI
Hello,
I have a washing machine (Bauknecht WAK74 (8583 642 03011) ) that had an F8 error due to a bad heating element. After changing it, the washing cycle (also the test program when hitting the "löschen" (delete) button a couple of times does more or less ) runs through, it is heating fine, but the F8 error is still being displayed.
I checked, cleaned, enhanced all the contacts, also of various other places I could reach to make sure it won't detect it e.g. due to vibration shortly causing a higher impedance.
I am a bit out of my comfort zone here (usually doing industrial stuff) so not having any experience with the brand and only service manuals from similar machines I am not quite sure if
- there is something else that could cause the F8 error that happened during the repair.
- there is a procedure needed to reset the error from the machine
- the error is really triggered each time the program (or test) runs, or if it is saved in the eeprom
Unfortunately I don't have a "clean" eeprom to just overwrite the old one. One test I did though was disconnect the NTC, leading to another error, then reconnecting it. The test program would still display the NTC error, but after writing back the old eeprom it didn't. So my suspicion is that the current eeprom might somehow contain the F8 error and overwriting it with a clean one might be all thats needed...
( I also grabbed the µC code and tried to disassemble/decompile it in ghidra but didn't have the time to get very far with it)
Hi!
Tudnátok segíteni. Lenne ez a gép.
Ezt a kikopott motort , kicseréltem egy másik wh üzemi kondisra.
https://heilmann.hu/spd/710-65/Whirlpool-mosogatogep-fomotor-keringeto-szivattyu
Azóta nincs fűtés, előtte volt.
Végigcsinálja programot, de nincs hibakód. Valamit elrontottam, de mit....
A fent nevezett szárítógéppel lenne problémám. A gép ékszíj problémás volt, az ex tulaj cserélte/cseréltette a szíjat. A gép eszméletlen hangos volt mikor elhoztam, és nem fűtött. A dob nem volt rendesen felhelyezve a tartó görgőkre, ezért volt hangos, ezt megigazítottam. A fűtéssel nem boldogulok. Fűtőszál-ak rendben, hőkioldók szintén, ntc ok. A panelen hibát nem találtam. A programválasztó gombot 6 óra állásba tekrve és a schonen gombot 3 x megnyomva tudom tesztelni a perifériákat, ha jól gondolom. 8 ig lehet a startal léptetni, majd alapállásra vált. a 6. és a 7. állasban megy a fűtés. Így arra jutottam, hogy a szíj hiba miatt esetleg hibakód van tárolva, amit resetelni kellene. Nem tudok rájönni hogyan... Olvastam néhány topikot, de sem a 6 óránál 3 start, 7 óránál 3 start, se a 11 óránál törlés, sem a 2 óránál törlés sem segített. Ha valakinek van egyéb ötlete, ne tartsa magába.
