Hello,
I have a washing machine (Bauknecht WAK74 (8583 642 03011) ) that had an F8 error due to a bad heating element. After changing it, the washing cycle (also the test program when hitting the "löschen" (delete) button a couple of times does more or less ) runs through, it is heating fine, but the F8 error is still being displayed.
I checked, cleaned, enhanced all the contacts, also of various other places I could reach to make sure it won't detect it e.g. due to vibration shortly causing a higher impedance.
I am a bit out of my comfort zone here (usually doing industrial stuff) so not having any experience with the brand and only service manuals from similar machines I am not quite sure if
- there is something else that could cause the F8 error that happened during the repair.
- there is a procedure needed to reset the error from the machine
- the error is really triggered each time the program (or test) runs, or if it is saved in the eeprom
Unfortunately I don't have a "clean" eeprom to just overwrite the old one. One test I did though was disconnect the NTC, leading to another error, then reconnecting it. The test program would still display the NTC error, but after writing back the old eeprom it didn't. So my suspicion is that the current eeprom might somehow contain the F8 error and overwriting it with a clean one might be all thats needed...
( I also grabbed the µC code and tried to disassemble/decompile it in ghidra but didn't have the time to get very far with it)
A Privileg PWC 1716-os gép topikjában említettem meg ezt a gépet is.Ez azt csinálja,hogy ha elindítom akár tesztben akár programban,akkor elindítja a dobot de csak pár másodpercre,majd leáll,vár pár másodpercet,újra elindítja pár másodpercre,ismét leáll pár másodpercig,és harmadszor is ugyanez és ekkor dobja ki a kódot.Másik hibakódot csak egy esetben dob,ha lehúzom az NTC csatlakozót a panelról.Ha a dob forgását figyelő érzékelőt húzom le(ez egy csatlakozóban van az ajtó csukott állapotát figyelő érzékelővel),akkor hiába nyomom a startgombot nem indul el.Ez viszont logikus is,mivel nem érzékeli az ajtó zárt állapotát.Valamint akkor is ez az utóbbi történik,ha a négy vékony fekete vezetékes csatlakozót húzom le.Ezek a szivattyúnál lévő érzékelőhöz és a lábazat tetején lévő érzékelőhöz vezetnek.Ennél a két esetnél nem jelez semmilyen kódot.Ez a három csatlakozó kivételével bármelyik másik lehúzása nincs hatással a fentebb leírt hibajelenségre és az F10-et is változatlanul kidobja.Maga a kód a táblázat szerint a következő:a vezérlőpanel nem kommunikál az MCU-val.Ezt az MCU-t nem részletezi hogy micsoda,de én úgy gondolom,hogy a kezdőbetűk alapján Motor Control Unit vagyis motor vezérlő egység lehet.De javítsatok ki kérlek ha tévedek.A motor egyébként egy sima aszinkron motor egy üzemi kondenzátorral.Külön motorvezérlő panel(ami arra utalna hogy inverteres a gép)nincs a gépben.Ha magát a motorcsatlakozót húzom le a panelről,akkor persze nem forog a dob,csak a relé kattan és akkor is a fent leírt hibát produkálja.A különbség csak annyi a tesztben és a programban produkált hiba között,hogy programban a szivattyút is elindítja mielőtt a dob forogni kezd.Köszönöm ha elolvassátok.Segítségetek előre is köszönöm.Üdv:Ladakölyök
Van egy Bauknecht WA Pure 16BW (Whirlpool) mosógép nálam. Minden megy rendesen rajta, de a centri nem pörög fel rendes fordulatra. Se mosóprogramnál, se sima centri programnál. 17 percet kiír centrizésre, 12-13nál jóideig pörget ballra-jobba, de a rendes furdulatot messze nem éri el, és 12-13 perc után (amin dolgozik vagy 5-6 percet) kiírja hogy END, pedig 1600-as fordulatok kellene mennie.
Szerintetek mi okozhatja a hibát?
Köszi előre is a segítő szándékot.
Sziasztok! A fent nevezett szárítógép bekapcsolás után pár mp-ig rákapcsolja a fűtést de utána leveszi és nem szárít! Az lenne a kérdésem,hogy- ha van benne nedvesség érzékelő -hol van?Melyik részén? Milyen elven működik?Valaki ismeri ezt a gépet jobban(nálam)?Már több is került ide ebből a fajtából meg a Whirpool-változata is és nem igazán tudtam elmélyedni bennük.
Köszi a választ!
