BBK DW9937S
VIDEO-DVD - SERVICE MANUAL
8.9 MB
Looking for similar bbk manual?
BBK DW9937S service manual (1st page)
Preview of BBK DW9937S [1st page]
BBK DW9937S service manual (2nd page)
Preview of BBK DW9937S [2nd page]
    BBK DW-9937S DW9937S DW 9937
Sony Sl-S770 vcr interrupted playback and AV display issues
I'm encountering an issue with my Super Betamax player. During playback, some cassettes abruptly stop playing at seemingly random points, accompanied by a sound similar to the one made when a tape reaches its end. This interruption also renders the rewind and forward buttons unresponsive. However, it does not impede the manual forwarding or rewinding of the cassette. The only solution seems to be ejecting the cassette and reinserting it. Occasionally, even this workaround fails, allowing only two seconds of playback before the problem recurs.
I sought guidance from the Mister Betamax troubleshooting page, which indicated that the tape safety device might be the root cause. I received additional advice suggesting that the issue could stem from one of the sensors within the VCR, possibly due to oxidized contacts causing intermittent operation. It was recommended to resolve this by carefully cleaning the contacts on the sensor switch responsible for detecting loaded tapes or the sensor that detects if the tape is "record-protected." Another suggestion was to monitor the output of these switches using an oscilloscope or voltmeter to determine if they are indeed the source of the problem.
I'm eager to hear if anyone has additional advice or personal experiences to share regarding this issue.
Additionally, I'm facing an AV cable problem where the yellow AV cable fails to display any video. While it used to work correctly, the AV audio cable still functions properly. As a temporary workaround, I've been using a coaxial cable and routing it through another VCR to utilize its AV output. However, I'm interested in exploring potential solutions to fix the issue with the yellow AV cable, if possible. Any insights or suggestions would be greatly appreciated.
VCR Panasonic NV-260 (Esquema eletronico da fonte)
Hello everyone, thank you for participating in this forum. I need the electronic layout of the Panasonic NV-260  video source. I have already researched several lines without success. Does anyone have this electronic schema?
Panasonic NV-HD100EG video bontása
Sziasztok! Ez volna: http://kepfeltoltes.hu/view/120930/Vide__www.kepfeltoltes.hu_.jpg Sajnos elég hiányos. Nem akarnám darabokra szedni mielőtt meg nem kérdezlek titeket, h. így egyben tudtok-e valamit használni belőle? Felújítani sztem ilyen állapotban szinte esélytelen :( Szalagkábelét is kitépték, elviekben az kuka benne... Üdv: Pityesz
THOMSON VTH6400E A kezelőgombokról nem megy MEGOLDVA
Jó napot mindenkinek! Amikor a saját gombjairól akarom üzemeltetni, kiírja hogy SAFE.Nem emlékszem hogy kell feloldani a zárat.A távszabályzóról megy. Elég fura helyzet mert a sajátom és megvan vagy 6-8 éve.Valamikor tudtam de elfelejtettem. Most nem tudom hogy került bele. üdv. dínó
