BECKER MEXICO 2000 JAPAN BE1436 NO CODE 85C82
CAR-AUDIO - EPROM
Type: (BIN)
256.0byte
CAR-AUDIO
EPROM
Looking for similar becker manual?
    BECKER MEXICO BE-1436 CODE 2000 JAPAN BE1436 NO 85C82 BE 1436 85 82
Becker Cascade BE7944 need help!
Hello to everyone!
Thanks in advance if someone can help)
I have a problem with replacement of malfunctioned final amplifier at Cascade BE7944.
It is play sounds through front loudspeakers with distortion.
It is not a problem with wires (I have tested it them with ohmmeter) and loudspeakers (brand new).
I have replaced with Traffic pro and it worked fine.
Radioengineer has announced the verdict - problem with final amplifier and it is must be replaced, and preferably with service manual or schematic, which I do not have. And I did not allow him to unassemble my Becker just "for to watch how it is looks from inside")
The problem is following:
1. Do someone have and can share with me with service manual or schematic of Becker Cascade BE7944.
2. As far as I understand BE7944 is further development of schematic Audio 10 ECE Typ 6011 (or 4011), which service manual is available at Internet - can I use it as general background for BE7944?
3. At present time unfortunately there is no possibility to find original MLT TDA 7454, only CHN or unnamed versions. I do not want to install that, but according to datasheet for TDA 7454 it can be replaced with TDA 738 *. And TDA738 * can be raplaced with TDA 7560 or TDA 7850 (in my case TDA 7851 L). If it is possible to replace TDA 7454 with TDA 7851 L and with which modifications? And will I not lose the “Backer surround” function?
4. Any other suggestions? Please withought "sell this dinosaur"
 I have written to Harman / Becker with this problem but still no answer ...
Thanks to all!
Becker BM54 modult (esetleg BM53-at) KERESEK!!!
Sziasztok! Keresek Becker/Harman BM54 modult akár működésképtelent is! A gyári végfok kiiktatása után történt egy kis baleset sajnos. Nem forrasztottam le az IC-ket, hanem netes leírások alapján átvágtam a panelon a szükséges fóliasávokat, viszont sajnos én marha azt hittem ez a panel csak sima 2 oldalas, de utólag ahogy néztem rájöttem, hogy van még egy réteg benne és sajnos belevágtam a hátlapi panelon több vezetősávba, legalábbis nagyon úgy néz ki. Így ki sem merem próbálni nehogy több kárt okozzak a többi részegységben. Vagy egy ilyen panelre lenne szükségem, amin a hátlapi ISO csatlakozók és a műveleti erősítők vannak, mert ez kompletten kiforrasztható és cserélhető, vagy pedig egy komplett ilyen modulra, akár végfokhibásan is. Ahogy nézem a BM53 is ugyan ez ránézésre, az is megoldás lehet. Már sokat nézelődtem, de horror áron van mindenhol, annyit nem ér az egész.
Becker BE6025 autós fejegység gombokra nem reagál - szerviz módban indul - Megoldva
Ez a fejegység a garázs szomszédom régebbi mercijében van. Egyik napról a másikra elnémultak a gombok, egyedül a hangerő encoder működik. Gyújtásra ki - be kapcsol, de a hangerőn kívül semmire nem reagál.
Állítólag nem ritka hiba ezeknél.
Egy fórumon valaki megjavította, de nem tudok oroszul a google meg valami ismeretlen szót ír:
Lezárom a témát, lecseréltem a protsyk-ot és minden működött.
Ezt nem tudom mi lehet...
Link:
https://monitor.net.ru/forum/threads/384471/
Lehet egy beragadt gomb, de kitűnő állapotban van, és nem hinném hogy gomb hiba - de átméregetem ha sikerül hozzáférni.
Beindítani sem sikerült még az autó nélkül, de ez úgy látom másoknak is nehezen sikerült.
Joco
Az autóba visszatéve rendben működik. Tehát kiszedve csak tápot ráadva NEM működik fél percig. Csak szerviz módba indul, de úgy is zombi - csak a logó van a kijelzőn.
Hogy mi volt a készülék hibája azt nem tudom. Talán valami kontakt hiba, vagy eleve rendbe jött volna a tápelvételes újraindítástól. Így legalább értem miért nem találtam semmi hibát a méregetés közben.
Keresem a HARMAN/BECKER Q01 autó rádió service manuálját
Én nem értek az autórádiókhoz.
Szivességből keresem a fotón látható autóradió doksiját . Apropó
 Melyik a tipusszám ? Kiegészíteném a fejlécet . Feltenném a Keresem/WANTED dobozba.
Megértéseteket köszönöm.
Üdvözlettel varga janohttps://drive.google.com/file/d/19Vg3GJxAwDY6-OHtoOoL-hIgzM8Y8Uyv/view?usp=drivesdk
Ez az erősítő egy Mercedes-Benz S-osztályú autóra van felszerelve, S300\ S350\ S400\ S450\ S600
2010 körüli modellek
