BRANDT S201 GWK WK RADIO 1940 SCH
690.2 KB
Looking for similar brandt manual?
    BRANDT S-201 WK RADIO S201 GWK 1940 201
ION Archive LP Turntable
This is a compact design to I guess transfer the vinyl into MP3 format.
Complaint was when the arm was moved the tt dont spin, confirmed that as
theres a leaf switch to sense arm movement,
and its fed to a main pcb with all the IC's that I guess handle all the
stuff. The switch is ok, and I remember seeing 14V or so on the motor pins
frm the PCB, so I figured perhaps theres anough current to spin the motor and
focused on testing the motor.
Manufacturer does not supply the mainboard that feeds the motor but
the motor can be taken apart and after I opened it and
disconnected the small pcb fron the motor terminals and apply power
directly, it spins w 12v. theres a small electrolytic cap on the pcb 25V / 22uF and an
AN6652 4 pin T0-220 type case IC that I guess is some kind of speed control
circuitry.
The drive Motor is an EG-530-SD-3F, main board is stamped K-13007.
Gonna check the cap, but after searching this IC and its
applications with the motor, I see its popular and some drawings show how its used to regulate the 78,33
and 45 rpm speeds.
This drawing looks pretty much what I see in there:
https://tectronelectronics.eu/images/thumbnails/465/465/detailed/31/eg530.jpg
I have replaced the IC and the cap, but the motor still does not turn. The main pcb
is proprietary and cant be purchased, and I think it is giving the op-amp IC a reference signal.
Is there a way to bypass that signal or fool the IC to believing its on to test it out?
Photo showing the motor pcb :
http://www.mediafire.com/view/s79blgku1503mtg/HPIM0643.JPG/file
Photo of motor under test:
http://www.mediafire.com/view/thhgvcwac8al7gu/HPIM0635.jpg/file
Sony cdm58 3cd-s mechanika beállítása
Üdv! Keresném a címben említett sony cdm58 cd mechanika beállítási útmutatóját. A cd mechanikát kéne újrapozícionálni de sajna saját kútfőböl nem megy. A szervízkönyvekben csak robbantott ábra található, legalább 10-et átnéztem. Létezik CDM58 mechanism alignment címszóval csak letölthető verziót nem találtam. Ha valkinek lenne kérem szánjom meg. Előre is köszönöm!
Samsung AV-R610 5.1-es erősítő kb. 15 perc után kiírja és kikapcsol ,hogy Protection {védelem}
 Tiszteletem!
Valaki tudna segíteni abban,hogy a Samsung AV-R610 5.1-es erősítő kb. 15 perc után kiírja és kikapcsol ,hogy Protection {védelem}
Nincs túl melegedve és megy benne a ventilátor is. Hol keressem a hibát benne?
Trafótekercselés
Szervusztok!
Tud valaki ajaánlani (lehetőleg Dél-Pest környékén) megbízható -és persze, viszonylag olcsó- trafótekercselőt?
Egy WSH110 trafóról volna szó, amit leégettek, a primerje biztosan zárlatos.
Köszönettel:
