BRAUN 4W6 1935 SCH
Type: (PNG)
72.5 KB
Looking for similar braun manual?
    BRAUN 4W6 1935
Yamaha CDX-590 laser adjustments?
I have a Yamaha CDX-590 CD player and it skips on some CDs - original CDs, these CDs play without problems on my other CD players. I have changed the laser unit (KSS-210A) but this didn't solve the problem. When I turn the player upside down, it plays the problematic CDs without a problem. That's why I think the laser needs adjustment. I have only a service manual for the CDX-493/593 but they should be very similar to the CDX-590. It seems that the adjustments are done via "test mode" of the CDX-590, unfortunately there is not much information, how to exactly, in the service manual. Here is a picture of the PCB. http://www.volny.cz/hwtest/PCB.JPG Here are the "test mode" sections of the service manual. http://www.volny.cz/hwtest/TM1.GIF http://www.volny.cz/hwtest/TM2.GIF In "test mode" I have tried Auto adjustment mode 1, 2, 3, but I don't know if it should work fully automatic without any intervention or when the mode is fineshed and I can proceed to the next one. So I activated mode 1, waited a while, activated mode 2, waited a while, activated mode 3, then exited test mode. It didn't help. Mode 1 - only a short blink of two horizontal dashes on the display and thats it Mode 2 - started "play" without sound from a strange time 99:00 (the test CD is not so long), after a while it skips to another time, "plays" a while, then skips back and "plays" and so on, I left it about an hour and it was still going on Mode 3 - seems to be very short as mode 1 I think I'm missing something ... Maybe someone did this or even serviced Yamahas in an official service and can provide information how to adjust the laser? Or maybe the problem is not the laser?
Hilfe! SAMSUNG 909 mini audio torony CD lejátszó mechanikája hibás.Megoldva.
Hellóka! Hogyan lehet levarázsolni a CD forgótárat a meghajtó tengelyről? A robbantott ábrából nem sikerült kisilabizálnom. Hasonló SONY toronynál mindössze egy menetes csavar rögzíti a tárcsát a tengelyre. Várom az idevágó tudor tanácsát, előre is megköszönvén. U.i: A masina SM letölthető. Megoldva!
Panasonic RF-D10 rádió nem kapcsol be !
 Sziasztok ! Próbálom életre kelteni de a mellékelt két IC számomra ismeretlen , és úgy tűnik hogy a kapcsolási kísérlet  itt akad el !
Talán ha kapok a jelzett IC-kről infót akkor tovább tudok lépni ! Még érdekelne  IC401 IC402 IC 403   ZB Z7 Z3 jelöléssel ellátott IC-k A proci oszcillátora  megy és a tápfeszek is rendben vannak ! Várom segítőkész
válaszaitokat ! Üdv!
AIWA CX-NS202EZ CD egységéhez keresek rajzot és mechanika beállítási utasítást /ui. valamint javítási sgítséget/
Sziasztok! Ezen készülékhez keresek CD egység rajzot és mechanikai beállítási utasítást, vagy tapasztalati tanácsot. Üdv.:Ckó
