Hello,
Last week I picked up a nice Kenwood KA-3500 40watt intergrated amplifier in pretty good shape.
Upon using it a bit more, I noticed a bit of distortion at high volume, more so in the left channel. I checked the DC offset at the speaker terminals, and the L channel said 100 mV, while the R was 25 mV. I understand this isn't so good for the L channel at least, but unfortunately this amp doesn't have any DC offset adjustments. Am I right in saying that to fix this I'd have to replace the output transistors?
On a related issue, in the service manual I found the section on BIAS adjustment, and I read online how it can affect the DC offset. So I hooked up my voltmeter to the test points, and I got 4 mV on the L, and 8 mV on the R. In the manual it says should be 40 mV.....(!). Is there something wrong here? I tried carefully adjusting them, but they only go to 30mV with the pots fully on, this doesn't seem right to me.
I compromised at 20 mV BIAS for both channels, and now the DC offset is 50 mV for L, and 5 mV for R, which is better, less than half what they were. I'm wondering, will I damage anything doing this, should I put them back to where they were?
The service manual is on site here.
Let me know if you want me to upload an english copy of the Owner's Manual, it has a better schematic in it all on one page, easier to read.
I've also included some pictures. They're not my actual unit, but mine is exactly the same, but less dusty.
Thanks for reading this. Many thanks in advance, and have a peaceful Palm Sunday! :taps2:
Bellarmine
Hello!
Segitséget szeretnék kérni ugyanis kicseréltem az autoban az akut igy a Ford Sound 2000 tipusu magnom kodja eszált! Letöltöttem a FORD SOUND 2000 Series- kodkalkulátort de sajnos a kezelésével már elbuktam!!!
A magnon a következő adatokat találtam:
Model no:2014
Serial no:M140038
Part no:94FP-18K876-BA
Még van egy szám a cimkén kivül belepréselve a lemezbe amiről gondoltam "na ez lessz az!"de semmi!
FD2014SM140038
Megkérek mindenkit Segitsetek!
Tanko
Egy Philips FW-C155/22 Hi-FI-t azzal hoztak be, hogy a hang torz. Kis hangerőn jó, de ahogy felerősítjük, egyre torzabb. Az SM-keresőben van rajz, de pont a végfokról nem találtam. A végerősítő IC egy AN7124 tip IC, de erről sem találtam rajzot a datashet-ben, csak egy nagyon egyszerű skiccet. Sok bogarászás, kísérletezés után úgy javult meg a helyzet, hogy az IC 4. és 5. (ez test)lába közé beforrasztottam egy 10kohm-os ellenállást, így tökéletes lett, teljes hangerőn is. Szerencsém volt (?) nem tudom, mi a magyarázat, de jó lett a gép, amolyan "vak tyúk is talál szemet" módszerrel.
Megnyugtatásul meg tudná mondani valaki, hogy mi a magyarázat?
Köszönettel:
Kedves Fórumozók !
A fent említett Grundig R301 receiver kapcsolási rajzát keresném,
a kezelőegység processzora IC402 pozícióban: M34200M4-3585P
Itt a Tanyán nem találtam....:-(
Segítségeteket előre is köszönöm !
NZs
