DECCA AW3 P AWD47 BRONSWICK AW47 AC-DC RECEIVER 1942 SM
913.1 KB
Looking for similar decca manual?
DECCA AW3 P AWD47 BRONSWICK AW47 AC-DC RECEIVER 1942 SM service manual (1st page)
Preview of DECCA AW3 P AWD47 BRONSWICK AW47 AC-DC RECEIVER 1942 SM [1st page]
DECCA AW3 P AWD47 BRONSWICK AW47 AC-DC RECEIVER 1942 SM service manual (2nd page)
Preview of DECCA AW3 P AWD47 BRONSWICK AW47 AC-DC RECEIVER 1942 SM [2nd page]
    DECCA AW-3 AWD-47 AW-47 RECEIVER AW3 AWD47 BRONSWICK AW47 ACDC 1942 AW AWD 47 AC DC AC-DC
ION Archive LP Turntable
This is a compact design to I guess transfer the vinyl into MP3 format.
Complaint was when the arm was moved the tt dont spin, confirmed that as
theres a leaf switch to sense arm movement,
and its fed to a main pcb with all the IC's that I guess handle all the
stuff. The switch is ok, and I remember seeing 14V or so on the motor pins
frm the PCB, so I figured perhaps theres anough current to spin the motor and
focused on testing the motor.
Manufacturer does not supply the mainboard that feeds the motor but
the motor can be taken apart and after I opened it and
disconnected the small pcb fron the motor terminals and apply power
directly, it spins w 12v. theres a small electrolytic cap on the pcb 25V / 22uF and an
AN6652 4 pin T0-220 type case IC that I guess is some kind of speed control
circuitry.
The drive Motor is an EG-530-SD-3F, main board is stamped K-13007.
Gonna check the cap, but after searching this IC and its
applications with the motor, I see its popular and some drawings show how its used to regulate the 78,33
and 45 rpm speeds.
This drawing looks pretty much what I see in there:
https://tectronelectronics.eu/images/thumbnails/465/465/detailed/31/eg530.jpg
I have replaced the IC and the cap, but the motor still does not turn. The main pcb
is proprietary and cant be purchased, and I think it is giving the op-amp IC a reference signal.
Is there a way to bypass that signal or fool the IC to believing its on to test it out?
Photo showing the motor pcb :
http://www.mediafire.com/view/s79blgku1503mtg/HPIM0643.JPG/file
Photo of motor under test:
http://www.mediafire.com/view/thhgvcwac8al7gu/HPIM0635.jpg/file
Kenwood KT-1100D
Sziasztok! A címben szereplő tuner rajzára lenne szükségem. A tanyán található SD végű sajnos teljesen más. Nehezíti a dolgomat, h teljesen szét van túrva.
TECHNICS SE-EX320 (megoldva)
Tisztelt Szakik! A nevezett erősítőm javításához kérném a segítségeteket. Bekapcsoláskor haloványan felvillant a kijelzője egy pillanatra, majd sötétség és vége. A táp bekapcsol, egy-két kapcsoló reagál, de egyébként halott. Átnézés után kiderült, nincs -14, ill. -22 voltja. A Q708 és a Q707-en csak a tápról lejővő fesz mérhető, és a D708 zener földre (testre) zárlatot mutat. Én cserélném a zenert, ill. a Q708-at. Köszönöm a megtisztelő figyelmeteket, és segítségeteket! Imre
Sony HCD-RG55S minhifihez kijelző előtti plexi keresés
Üdv! Sajnos betörték (kijelző, minden más OK), ha lenne valakinek bontott ilyen készüléke, vevő lennék a plexijére, vagy a komplett előlapra: http://www.kephost.com/view3.php?filename=56lgkrzav1uuxvx7gxz2.jpg HCD-RG55S (MHC-RG55S) THX!
