Problem with Denon-Heos-AMP HS1
Cause:
After a factory reset attempt that fails, the following problems occur.
PS
The unit worked just before the factory reset!
Problem:
The device tries to update the firmware automatically (online), but it fails.
The device then flashes red continuously.
According to the service manual, the only option is to load a new factory firmware using a USB dongle.
After many hours of searching the web, I have not been able to find this firmware file.
The service manual refers to an SD (service disk).
The Denon service office does not sell or provide service application software.
I hope for further information/help to solve this problem
Regards Mogens
Most hozták azt az erősítőt, hogy nem lehet bekapcsolni. Szétszedés után a biztosítékok épek, ellenőrizve a transzformátor a kimenet jó, de a primer szakadt. Ez toroid trafó, és van-e benne hővédelem, de ki van öntve az alja? Ki javítja ezeket a trafókat az országban? Teszek fel képeket is!
Hello everybody,
This receiver starts normally and has a nice blue display lighting on for 8 seconds. Suddenly you ear the main relay falling down and everything turns off and you get the red led flashing around the main power switch button. There is no special code with this continuous flashing rythm of the led. I have no diagram of the device and I have opened it and measured the voltage on pin 4 of the voltage regulator KIA78R05P1, which has a validating signal on his pin four.(2 is the output and 3 is frame (-)).this 5V(to-220)monolithic 7805 regulator is on the main PCB, close to the little transfo and ON/OFF relay...and is mounted without any heat dissipator(I was surprised of that fact!).the voltage between(4-3)is 1,88V dc and never climbs up during the starting sequence.
Can you help me to solve this problem?
Kedves Hozzáértők!
Vettem magamnak egy ilyet. Az erősítő részt már rendbe raktam (hangszóró relé, potik, kapcsolók kh-sak voltak), de a rádió továbbra is féloldalasan szólt.
Megnéztem a tuner némító tranzisztorokat, de azok jók. A kimenetükön szkóppal nézve féloldalas, de az előttük lévő 2.2u/50V-os kondenzátorok bemenetén a jel szintje mindkettő csatornán jó.
Próba képpen leválasztottam a bemenet választó IC-ről (TC9164/NJU7313) a tunert. A bemenet választó egyik csatornáján 2V DC mérhető, a másikon 15V DC!
Ebből arra kövtkeztetek, hogy ez az IC kissé döglődik.
Csak az érdekesség kedvéért beszúrtam a tuner és a bemenet választó közé egy-egy 10u/50V-os kondit. A rádió így szimmetrikussá vált, tisztán szépen szól.
Kérdés: küzdjek az IC cseréjével, vagy fixálhatom ezt a beszúrt kondenzátoros megoldást? Nem okoz majd nagyobb kárt?
Megoldás: A TC9164N bemenet választó IC cseréje megoldotta a problémát. Köszönöm mindenki segítségét.
Gábor
Gábor
