Került hozzám ez a nagyon régi Hi-Fi-s darab javításra.
Alkatrészről szeretnék meg tudni valamit hogy mi ez egyáltalán, neve D313. Tokozás: TO-220
Van még egy FS 7805 M jelű stab IC az "M" mit jelöl? szintén TO-220 tokban
A segítséget előre is köszönöm!
A hiba 7805 stab Ic zárlata okozta, csere után a készülék bekapcsol és köszöni szépen jól van :)
Üdv Stewe
I have a Yamaha CDX-590 CD player and it skips on some CDs - original CDs, these CDs play without problems on my other CD players.
I have changed the laser unit (KSS-210A) but this didn't solve the problem.
When I turn the player upside down, it plays the problematic CDs without a problem.
That's why I think the laser needs adjustment.
I have only a service manual for the CDX-493/593 but they should be very similar to the CDX-590.
It seems that the adjustments are done via "test mode" of the CDX-590, unfortunately there is not much information, how to exactly, in the service manual.
Here is a picture of the PCB.
http://www.volny.cz/hwtest/PCB.JPG
Here are the "test mode" sections of the service manual.
http://www.volny.cz/hwtest/TM1.GIF
http://www.volny.cz/hwtest/TM2.GIF
In "test mode" I have tried Auto adjustment mode 1, 2, 3, but I don't know if it should work fully automatic without any intervention or when the mode is fineshed and I can proceed to the next one.
So I activated mode 1, waited a while, activated mode 2, waited a while, activated mode 3, then exited test mode.
It didn't help.
Mode 1 - only a short blink of two horizontal dashes on the display and thats it
Mode 2 - started "play" without sound from a strange time 99:00 (the test CD is not so long), after a while it skips to another time, "plays" a while, then skips back and "plays" and so on, I left it about an hour and it was still going on
Mode 3 - seems to be very short as mode 1
I think I'm missing something ...
Maybe someone did this or even serviced Yamahas in an official service and can provide information how to adjust the laser?
Or maybe the problem is not the laser?
Üdv. Mindenkinek!
Segítséget szeretnék kérni, egy végfokozat javításában.
Hibajelenség: a kicsatoló kondenzátoron, a negatív oldalon, a hangszóró csatlakozónál, egyen feszültség 24V van.
Táp feszültség: 39V.
A 10 ohm - os ellenállás félpercen belül forró lesz.
Azért érdekes ez a jelenség, mert ezt az erősítőt már megépítettem, kb. húsz éve, és kifogástalanul üzemel. Ilyen hibával még soha nem találkoztam, a kicsatoló kondi után nem volt egyen feszültség. Tehát, a hangszórókat biztonságosan lehetet csatlakoztatni.
Kapcsolásirajz, Sipos Gyula könyvben az 1978-as kiadásban található, a 144. oldalon 109-es ábra.
sziasztok.van egy ilyen szép darabom vadi új alfába való.autóban még nem volt.tápot adtam neki és csak a "canchek" felírat jelenik meg a kijelzőn.a can bus hiányát mivel lehetne pótolni,vagy valami más ötlet.
