DIGMA HIT HT 7070MG MEDIATEK MT8382 TABLET PCB SCH
OTHER - SERVICE MANUAL
668.0 KB
Looking for similar digma manual?
    DIGMA HIT HT MEDIATEK MT-8382 PCB 7070MG MT8382 TABLET 7070 MG MT 8382
SMD alkatrész beazonosítás
Két SMD alkatrész beazonosításban kérnék segítséget. A két összekötött láb diódákra utalhat, de nem mindegy, hogy merre áll és mennyi van a tokban. Képet csatoltam.
LG PF1000U Ultra Short Throw Projector (chassis FM51E) Firmware
Good afternoon!
I'm looking for a dump for the LG PF1000U projector (chassis FM51E), (NAND Hynix H27U1G8F2CTR SPI_FLASH: MX25L8035EM2I, EPROM 24C256C).
There is no epk file available anywhere :(
This device attempts to turn on and responds to both buttons and the remote control:
It exits standby, runs the fans for 5 seconds, then spins them at 100% for another 5 seconds judging by the sound, and then goes back into standby.
The problem seems to be a corrupted NAND as it appears to me:
[ 0.110000] NAND device: Manufacturer ID: 0xad, Chip ID: 0xf1 (Hynix NAND 128MiB 3.3V 8-bit)
[ 0.110000] redirect_size = 400000, redirect_start = 7c00000
[ 0.110000] Loading nand bad block info(00000000+00020000)...
[ 0.119000] Mstar nand-flash partition definition
[ 0.119000] mtd info: # of partitions = 23
[ 0.119000] Creating 23 MTD partitions on "NAND 128MiB 3.3V 8-bit":
[ 0.119000] 0x00000000-0x00020000: "bbminfo"
[ 0.120000] 0x00040000-0x00060000: "mtdinfo"
[ 0.121000] 0x00160000-0x00760000: "rootfs"
[ 0.121000] 0x00760000-0x007c0000: "lginit"
[ 0.122000] 0x007c0000-0x007e0000: "crc32info"
[ 0.123000] 0x007e0000-0x00800000: "model"
[ 0.124000] 0x00800000-0x00900000: "logo"
[ 0.124000] 0x00900000-0x00a00000: "cmndata"
[ 0.125000] 0x00a00000-0x01200000: "nvram"
[ 0.126000] 0x01200000-0x01300000: "user"
[ 0.127000] 0x01300000-0x01400000: "ezcal"
[ 0.128000] 0x01400000-0x014a0000: "estream"
[ 0.128000] 0x014a0000-0x01620000: "opsrclib"
[ 0.129000] 0x01620000-0x018a0000: "kernel"
[ 0.130000] 0x018a0000-0x03560000: "lgapp"
[ 0.131000] 0x03560000-0x04fa0000: "lgres"
[ 0.132000] 0x04fa0000-0x05be0000: "lgfont"
[ 0.132000] 0x05be0000-0x05c00000: "tplist"
[ 0.133000] 0x05c00000-0x07640000: "lgres"
[ 0.134000] 0x00080000-0x000a0000: "cert"
[ 0.135000] 0x000a0000-0x00140000: "authcxt"
[ 0.136000] 0x00060000-0x00080000: "hdcp2"
[ 0.137000] 0x00140000-0x00160000: "keyrsrv"
[ 0.138000] mod_nand_init is invoked
[ 0.138000] GE driver inits
[ 0.138000] mod_iic_init is invoked
[ 0.138000] model option = 0xfc
[ 0.138000] Mstar_emac: [PHY Addr] ==> :0
[ 0.138000] Mstar_emac: alloRAM_VA_BASE = 0xA0C40000 alloRAM_PA_BASE= 0xC40000 alloRAM_SIZE= 0x100000
[ 0.139000] RBQP_BASE = c44000
[ 0.140000] [SCALER][000173] _mod_scaler_init
[ 0.140000] [TTX_DRV][00508]init 170
[ 0.140000] MDrv_CC_Init
[ 0.140000] init 172
[ 0.140000] [DEMOD_DRV][00369]init 245
[ 0.140000] [BDMA_DRV][00629]init 251
[ 0.141000] TCP cubic registered
[ 0.141000] NET: Registered protocol family 17
[ 0.142000] RPC: Registered udp transport module.
[ 0.142000] RPC: Registered tcp transport module.
[ 0.142000] Adding user_initcall[0] = 0x803a1314
[ 0.142000] Adding user_initcall[1] = 0x803a1320
[ 0.142000] Adding user_initcall[2] = 0x803a66f8
[ 0.144000] VFS: Mounted root (squashfs filesystem) readonly.
[ 0.150000] VFS: Mounted lginit (squashfs filesystem) readonly.
[ 0.150000] Freeing unused kernel memory: 132k freed
[ 0.204000] SQUASHFS error: Can't find a SQUASHFS superblock on mtdblock19
[ 0.225000] Empty flash at 0x000213bc ends at 0x00021800
[ 0.234000] Empty flash at 0x00023200 ends at 0x00023800
[ 0.242000] Empty flash at 0x00024bbc ends at 0x00025000
[ 0.250000] Empty flash at 0x000271ec ends at 0x00027800
[ 0.250000] jffs2_scan_inode_node(): CRC failed on node at 0x00028fe0: Read 0xffffffff, calculated 0x916f9a2e
[ 0.258000] Empty flash at 0x00029120 ends at 0x00029800
[ 0.264000] Empty flash at 0x0002ab84 ends at 0x0002b000
[ 0.289000] Empty flash at 0x00040878 ends at 0x00041000
[ 0.289000] jffs2_scan_dirent_node(): Node CRC failed on node at 0x000427f4: Read 0xffffffff, calculated 0x2322e93d
Thank you in advance!
MERCURY Smart PRO 1200 alkatrész beazonositása
köszöntem
javitani kell,de hiányzik egy alkatrész
a nyák lapon ugy van jelölve,hogy DS1
gömbölyű,mintha elko nak a helye lenne
mi lehet az?
Pfaff 807 varrógép ZAVARSZŰRŐ csere 4+2 kivezetés
Sziasztok! adott a képen látható mechanikailag szuper állapotban levő Pfaff hobbymatic 807 varrógép 1982-ből.
Elpukkant a belső kondi rajta. 4 éve ugyanezzel már javítva volt szervizben. Akkor nem faggattam a szerelőt, h pontosan hogy lett javítva. Amit nem értek, hogy látok benne egy szintén megkímélt állapotú motor egységet, rajta egy kondenzátorral ami viszont tuti nem új.
Kérdésem,
  • Lehet a szerelő úgy javította, hogy az egész motort cserélte egy jó állapotú bontottra?
  • ez egy 6 kivezetéses kondenzátor, mondjuk annyit látok hogy az egyik a testre van kötve.. honnan lehet ilyen kondenzátort szerezni?
  • az, hogy egy kondenzátor hat kivezetéses, még több fajta elrendezést takarhat..? pl miflex-nél egyfajta 6os van.
Ja meg hát ami a lényeg, hogy lehet ezt megcsinálni? :D
új kondenzátort szeretnék, mert mindkét alkalommal a lehető legrosszabbkor ment tönkre. Ezúttal megbízhatóra szeretném.
tippeket köszönöm :)
